Bike stuttering at constant speeds
Re: Bike stuttering at constant speeds
rvkssl wrote:So, finally got the parts from Thailand, changed the TPS, did a TPS reset and made a testride, at first i thought the problem was fixed but when the bike warmed up the same thing happend again, stuttering at constant speeds......... :oops: :oops: , could this kind of symptoms come from the drivetrain?
Do you not trust your authorized Honda dealer to run a diagnostics on it?
easyrider
Color: blk
Post by easyrider »
Check ignition circuit. Coil,spark plug.Fuel pressure.
rvkssl
Color: Pearl white
Post by rvkssl »
I had a recall from the local HONDA dealer, the LED control unit had to be replaced, so i thought that this was the best oportunity to let them take care of the problem.
When i got the bike back, the LED unit was replaced but they couldn't find the fault, the simple reply from the mechanic was: there wasn't any fault stored in the memory, i drove it but couldn't find anything wrong... :oops:
It's the same problem i also encouter with my cars, you do a lot of research, swap parts like hell, can't fix the problem and the last resort is the stealer which nicely replies "we couldn't find anything" and oh yeah here is the bill for the troubleshooting.
My next thought is the fuel pump and filter, just ordered it, we will see...
Cheers, Ronald.
rvkssl
Color: Pearl white
Post by rvkssl »
No Fish, just paid $40,- for nothing (again)
DAB
Post by DAB »
rvkssl wrote:Checked belt and rollers, bypassed side stand switch, changed spark plug, still no luck...., i also cleaned out de VS sensor, no test ride made yet.
I didn't check the TPS yet Fish, i want to start with the easy stuff before taking all the plastic off ( again :( )
Is this the original belt. what do you mean by igniter? spark plug or coil.
Other rides
rvkssl
Color: Pearl white
Post by rvkssl »
spark plug or coil.[/quote
Yes, original belt, and i meant the spark plug.
Have you had a look at the air filter? (could not see that mentioned in the thread)
DAB
Post by DAB »
You say stuttering at constant speed, is this any speed? When you inspected the belt did you take any measurements or just a visual check?. Has your maximum speed decreased?
Other rides
rvkssl
Color: Pearl white
Post by rvkssl »
DAB wrote:You say stuttering at constant speed, is this any speed? When you inspected the belt did you take any measurements or just a visual check?. Has your maximum speed decreased?
It stutters at any speed, mostly when engine is warmed up, i've checked and measured the belt, within limits, maximum speed did not drop, i even checked the engine with belt removed to rule out the drive train, same issue, you can feel the engine stutter running on the center stand.
As you say when warmed up, could be the air temp sensor (this is seperate from the TPS)
easyrider
Color: blk
Post by easyrider »
Have you checked fuel pressure?Fuel pump?
DAB
Post by DAB »
Is the spark plug a good colour? I think I would try checking the coil.
Other rides
rvkssl
Color: Pearl white
Post by rvkssl »
iceman wrote:As you say when warmed up, could be the air temp sensor (this is seperate from the TPS)
Iceman, i think the TPS assy holds 3 sensors including the air temp. sensor, i already replaced it.
rvkssl
Color: Pearl white
Post by rvkssl »
easyrider wrote:Have you checked fuel pressure?Fuel pump?
I will replace the fuel pump as soon as it arrives the following days.
rvkssl
Color: Pearl white
Post by rvkssl »
DAB wrote:Is the spark plug a good colour? I think I would try checking the coil.
The spark plug's colour is o.k, i have tried to measure the ignition coil, but my Fluke won't let me...
DAB
Post by DAB »
Could it be that the fuel tank is not venting, Still would have the coil checked as the problem occurs when the engine is warm.
Other rides
grndslm
Post by grndslm »
If it only stutters at constant speeds, then the fix is easy....
Just keep twisting the throttle back and forth!!
Only partly kidding, but I feel after all this trouble you've gone thru, you should be able to describe the problem with a little more detail now. Exactly when does this stuttering happen and/or NOT happen. What does it feel like? Where do you feel it? Does it feel like clutch pads slipping, by chance? Probly not... but ya never know, I guess.
rvkssl
Color: Pearl white
Post by rvkssl »
DAB wrote:Could it be that the fuel tank is not venting, Still would have the coil checked as the problem occurs when the engine is warm.
Thanks DAB, i will do this when the fuel pump doesn't fix the problem.
rvkssl
Color: Pearl white
Post by rvkssl »
After some other project, personal problems and wintertime i've finally found time to change out the fuel pump, and.........
YES!!!!, Problem solved ! bike rides like a charm again, finally after all these months i'm enjoying my PCX again. :D :D :D
Rock 'n Roll. Congrats!!
