2013 luggage box vs. a 2015 luggage box
Adonai1st
Post by Adonai1st »
Hi, I need to replace the luggage box on my 2013 honda pcx150, however a new one is about $130. However, I found a 2015 pcx150 luggage box brand new that's around $40. Does anyone happen to know if the 2015 one will fit on a 2013 bike? Thx.....
ItBeMe
Color: Very dark blue
Re: 2013 luggage box vs. a 2015 luggage box
Post by ItBeMe »
You can make it fit if you are handy with tools.
Adonai1st wrote:Hi, I need to replace the luggage box on my 2013 honda pcx150, however a new one is about $130. However, I found a 2015 pcx150 luggage box brand new that's around $40. Does anyone happen to know if the 2015 one will fit on a 2013 bike? Thx.....
What type of box are you referring too, a Honda OEM one, or something different? My understanding is that it is not so much the box that could be different, but the mounting bracket and plate. If it is a Givi, you are likely okay, as long as it is the same model type (i.e. Monolock or Monokey).
As well, it helps us to help you better if you include your location with your profile, which you can update through the 'User Control Panel' in the upper right corner of your screen if you are on a computer.
Adonai1st
Post by Adonai1st »
Sorry, I should've specified. I'm referring to the storage box under near the seat....
Adonai1st
Post by Adonai1st »
Just found a cheap 2013 pcx 150 OEM one which I just ordered... :)
ItBeMe
Post by ItBeMe »
What happened to the old one, never heard of anybody replacing one.
Adonai1st
Post by Adonai1st »
ItBeMe wrote:What happened to the old one, never heard of anybody replacing one.
It's a long story.... :D :) :) :D
Well, as an answer to your original question, just in case, No, the 2015 under seat box will not fit a 2013 model. They revamped the whole PCX in 2015. Hopefully you won't have any problems with the replacement one you found.
