Metal side panel, where to buy?
- Year: 2015 Forza 300
Re: Metal side panel, where to buy?
anyone? I need it!!
Why? For cooling or to look cool?kar120c wrote:anyone? I need it!!
What is it made of? A local sheet metal place might be able to make you one quickly.
- Color: grey
my 2014 Forza does not have that plate....
your pic made me go out to my garage to have a look!!
Do you know what it is for?
It is for access to the spark plug I think. Normally it is plastic with no vents.dergav wrote:?
I need only beacuse it is looking cool!
- DioTiAma
- Year: 2013 NSS300A
- Color: Seal Silver
Since you are so insistive... That thing is not an aftermarket part! It's a modification. You cut the existing piece of plastic and you combine it with a floor drain cover! Voilà!
- Floor Drain Cover.JPG (20 KiB) Viewed 3083 times
Re: ...
I am am so insistive because almost every Thai tuned Forza has this panel and it is the same for allDioTiAma wrote:Since you are so insistive... That thing is not an aftermarket part! It's a modification. You cut the existing piece of plastic and you combine it with a floor drain cover! Voilà!
Life has meaning once more
Ok, that's great! Sometimes it's the small things in life that makes one happy I get it. Me too, lots of times. Appreciate that others were trying to help by providing a different replacement. Cheers to You, you found it after all Can you share with us where? Thanks up front
2yous...Rejoice
2yous...Rejoice
From a Thai user of the "Forza Club Thailand", send me pm if you want more informationsWhiteNoise wrote:Ok, that's great! Sometimes it's the small things in life that makes one happy I get it. Me too, lots of times. Appreciate that others were trying to help by providing a different replacement. Cheers to You, you found it after all Can you share with us where? Thanks up front
2yous...Rejoice
Here you can see the part mounted on my Forza
upload immagini gratis
Nice!
Is it functional as well, or merely decorative? And if functional, in what way?
6 other previous bikes
2yous...Rejoice
Hurray..
I think it is only decorative but while running more air reach the engine and this should be an advantage.MBMyer wrote:Nice!
About rain, my mechanic told me is not a problem because spark has a rubber sealing
