What size hex driver do I need to remove the front axle of a Honda Forza 300?
It looks like a 16mm.
Front wheel removal
Re: Front wheel removal
You need two, one for the lock bolt and another for the spindle.
No idea what size they are though.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
On the PCX the spindle is 14mm and the lock bolt is 19.
Knowing the reuse engineering of Honda, I would be surprised if it would be different on the Forza.
The Forza 300 has a completely different wheel spindle attachment, there's no wheel nut, the spindle is threaded and you need a large male allen key to undo it.
- Oyabun
- Year: `12,`15,`19
My mistake then. Please disregard my previous post.
A 16 was too loose and my 17 would not fit but the Lordco store 17 did fit. I took a grinder to my 17.2 and made it a 17.davenowherejones wrote:What size hex driver do I need to remove the front axle of a Honda Forza 300?
Why when the second 17mm fitted?davenowherejones wrote:A 16 was too loose and my 17 would not fit but the Lordco store 17 did fit. I took a grinder to my 17.2 and made it a 17.davenowherejones wrote:What size hex driver do I need to remove the front axle of a Honda Forza 300?
Sooooo. As to size I'm suspecting its probably 17mm...
So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
6 other previous bikes
Nevermind. It’s an 8mm hex driver for the pinch bolt. And the 17mm fits perfectly for the axle.MBMyer wrote:So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
Sorry to trouble y’all for no good reason.
Michael
