Exhausts
Exhausts
This is my first post on here but I've been looking around for a while.
So im running 2011 125 black all standard expect the Air Filter which is a:
http://japan.webike.net/products/21747127.html
Which is nice is makes the bike sound nicer and look better of course, it also gives a little bit more acceleration
I've just brought a new exhaust which is :
http://www.ebay.com/itm/271734593072?_t ... EBIDX%3AIT
I was wondering if anyone else has fitted one and how it effects the bikes performance, sound and so on
If you have it would be nice to see a video of some sort
And even if you haven't its always nice to see what other people have fitted so please all share
PS: The bike is limited to 65 is there anyway I can change this
would fitting a aftermarket variator and lighter rollers help at all ?
Re: Exhausts
You've probably answered all your own questions.whitespiritkid wrote:This is my first post on here but I've been looking around for a while.
Re: Exhausts
You've probably answered all your own questions.[/quote]
I guess so but I just want to be sure before I actually change anything with the variator
Re: Exhausts
Lighter rollers increase acceleration. Too light, and you'll lose top speed(because the weights can't push the belt out all the way).
Variator can affect acceleration, but mostly determines top speed(your gearing).
The exhaust should give you a small bump up in power. Can't say what the noise level is like since I haven't used that particular one myself, but I doubt it'll be higher than a stock sport bike exhaust.
Re: Exhausts
Thanks what rollers would you recommend there's a lot of talk between 10grams and 13gramsValiant wrote:Lighter rollers increase acceleration. Too light, and you'll lose top speed(because the weights can't push the belt out all the way).
Im not to bothered about top speed to be fair would be nice to hit 70 top end im happy with that
But im also aiming to be able to get the bike popping would be nice if I could wheelie the bike that's more of my main goal
Re: Exhausts
I had pretty good luck with 13g. Would depend on your weight though. If you're not concerned with top speed, you could go with 10g. A tachometer would help a lot with seeing where you are on the weights.
Wheelie with the PCX is going to be about technique, as there is an electronic limiter that prevents a hard launch. You could use stiffer clutch springs so the clutch engages at high rpms(maybe 5000+), but IMO trying to do that is sort of pointless with the PCX.
The fairings are plastic, so even a light drop would crack a few. Tweaking your clutch engagement that high would make it very jerky when you're trying to move around the city.
If you just want to pop wheelies, why not get a dual-sport?
Re: Exhausts
I will go with the 10grams see how it goes , im a stickman 6ft weighing 60kgValiant wrote:I had pretty good luck with 13g. Would depend on your weight though. If you're not concerned with top speed, you could go with 10g. A tachometer would help a lot with seeing where you are on the weights.
I was going to get a dual sport but I needed to get something quick, to get to and from my new job and the pcx just looked amazing and I got it at a really good price
I wont play with the clutch yet I will wait for the exhaust and then play with the rollers see how it plays out
Re: Exhausts
Great stuff only thing is its a 170s got me thinking I wont have any luck unless I rebore
Re: Exhausts
Does the FiCon2 unit eliminate the takeoff delay?
Re: Exhausts
Ah. Bless.
Re: Exhausts
you you wrote:
Ah. Bless.
You can do slightly better by lifting your bum of the seat and when the bike accelerates hold onto the bars. It will still be slightly rubbish and people will be irritated or laugh at you but a wheelie is a wheelie.
Grip the bike with your knees when it comes up
Re: Exhausts
Ficon2 makes no difference, it's all in the vario tuning.Valiant wrote:Does the FiCon2 unit eliminate the takeoff delay?
This was a Takegawa vario with .6mm washer.
Re: Exhausts
You still around?!you you wrote:you you wrote:
Ah. Bless.
- Color: matte silver
Re: Exhausts
Your welcome to compare... Akrapovic to Yoshimura...
both have sound in MP3... so you can listen... your after performance right...!!!!
http://shop.yoshimura-jp.com/en/product ... p?id=15489
http://www.akrapovic.com/#!/motorcycle/ ... earId=3876
