Alrighty then!
I had the Daytona variator & AdvancePro Drive Face installed with 12g Dr Pulley Sliders, 2x 0.5mm washers, Takegawa Center Spring(+11%), and the KN Planning Torque Driver.
The delay is all but eliminated. There's a definite rpm lag when going from a stop to WOT, but it's also pulling straight the entire time whereas before it would just shudder and creep forward a feet or two before it "engages" and pulls forward. This setup feels more linear and more responsive to throttle control.
I can't say for sure what caused the issue as I didn't have them install one piece, then try it, as I sat around there for 2-3 hours(total work wasn't long, but they were working on 5 different scooters at once). But I suspect it was the variator, as Reggy mentions it's designed to keep rpms low until about 30 mph. Doesn't make sense to me, as heavier weights could achieve the same effect without having to design a whole variator around that.
Stand speed is 86 mph at 9600 rpms, so a definite bump up in the gearing. I haven't taken it on the freeway yet, so I don't know what the pulling rpms are at, or how the top speed will be affected. I know that city riding only requires about 10-15% throttle to maintain a 35-40 mph speed.
I'm happy with the results thus far, I'll see what the freeway speeds are at tomorrow, and if I need to order lighter sliders.
