NCY Variator, Face Plate, 13gr Rollers, Belt for 2013 150
Re: NCY Variator, Face Plate, 13gr Rollers, Belt for 2013 1
Right between 7900-7950 rpm full throttle starting from 30 mph.
- sendler2112
- Year: 2013 PCX150
7,900 rpm is just about ideal. You definitely don't want to go heavier. 12g might be slightly quicker 10-50 mph but not worth spending more money.
- Year: 2011 PCX 125
I installed the NCY variator, face plate, and 12g rollers on my 2011 PCX 125 (approx. 4,500 miles), and gave her a new OEM belt at the same time.
Pulling RPM full throttle: 7800-7900. Max speed (flats, no wind): 62 MPH (GPS).
I've subsequently installed a second, identical set (NCY variator, face plate, and 12g rollers) on my new 2013 PCX 150 (approx. 200 miles).
Pulling RPM full throttle: 8100-8200. Max speed (flats, no wind): 65 MPH (GPS).
I would have expected both speeds to be faster. I'm also surprised that the 150 is only 3 MPH faster than the 125. And that their pulling RPMs are different, given they're both running the exact same setup.
SCOOTS
Now: 2013 Honda PCX 150 / 2011 Honda PCX 125 / 2014 Honda Metro / 2014 Honda Metro
Before: 2015 Yamaha SMAX / 2009 Yamaha Zuma 125 / 2006 Yamaha Vino 50 / 2013 Honda Metro
WOOTS
1988 Volkswagen Westfalia full camper
WOOTS
Those speeds sound about right.
I get maybe 68 mph(GPS) on my 2015 PCX 150 when going downhill, and maybe 63-65 on flats(though wind is a universal constant on this island). I need an aftermarket air filter and Takegawa Silent Sport Oval Exhaust to get me there.
The PCX is not a powerhouse, and it would also depend on rider weight, what you're wearing, etc.
I suspect your 2013 might be able to go a bit faster once you fully break it in and change out the oil.
The speed does seem a tad low given that your 2013 should have a gearing advantage over mine(by maybe 3 mph), I weigh 200 lbs, wear a bulky armored jacket, and I have saddlebags loaded with 25 lbs of chains and a top box. So I've got plenty of wind drag on me .
- sendler2112
- Year: 2013 PCX150
It might be that the contra springs are a little different.typhon2222 wrote:I would have expected both speeds to be faster. I'm also surprised that the 150 is only 3 MPH faster than the 125. And that their pulling RPMs are different, given they're both running the exact same setup.
What is the rpm of the 150 at 65 mph?
65 mph??? Both my wife and i top out at 68 mph (gps) when we have new belts on out 150s. Right now she has a new belt, while my new belt is stored in my tailbox until i can change it out.
Mine did too with the stock parts but the 2015's are a little slower
- sendler2112
- Year: 2013 PCX150
Depends how much someone is willing to tuck.
today I received the Advance Pro large Diameter 120mm, 14 Degrees of Angle. I noticed that on the plate writes with embossed letters: PCX 120x14. isn't it problem for the belt?? the surface of the drive face shouldn't be smooth??
I have a general question. I looked at the drive face on corsportusa.com and it looked different than this one at webike:
http://japan.webike.es/products/21354758.html
Are they the same drive face? If not, is one preferred over the other?
Mel46 wrote:I have a general question. I looked at the drive face on corsportusa.com and it looked different than this one at webike:
check the fourth photo of the above link. It is the same as I described! about the embossed letters..
http://www.corsportusa.com/2010-honda-p ... rive-face/ this one?? it is not the same..
I have been riding the Forza a lot lately but I took the PCX for a short spin yesterday with a friend with a Harley and that NCY setup really makes it accelerate like a Banshee. I don't know how long term belt wear will be but the performance improvement is really nice. I may have a gained a mph on the top end with some more miles on the new setup.
It'll accelerate like a Banshee, but only up until the weights are locked out, which is about 50-55mph. While I can easily keep up with if not entirely blow past all cars and bikes under 500cc, it's an entirely different story on the highway where I'm following behind a really beat-up looking 250cc dualsport and I'm only slowly catching up on full throttle when I suspect the other guy is cruising comfortably on 3rd gear at a little over half throttle.SECoda wrote:I have been riding the Forza a lot lately but I took the PCX for a short spin yesterday with a friend with a Harley and that NCY setup really makes it accelerate like a Banshee. I don't know how long term belt wear will be but the performance improvement is really nice. I may have a gained a mph on the top end with some more miles on the new setup.
Still, having an aftermarket transmission really makes you less of a nuisance on the highway because merging and changing lanes is easier with the faster acceleration.
