ENGINE STRETCH BRACKET
Born in Indonesia as Island 🏝 boy, been living happily in Texas. I need help to get a hand of engine bracket to stretch my 2015 Forza abs, have no luck looking for it online. My Thailand neighbor, please do help me if y’all can. Also need more info what else do I need to stretch shot scooter.
So far I got lowering kit from bikerzbits
Thank you INSTAGRAM FOR DIRECT DM @ myni_mega
Few attachments if someone people wonder what it look like for the engine extensions
- F6345A26-CD1D-4C46-B127-6FE2F8C0FA83.jpeg (351.95 KiB) Viewed 1159 times
- 40663053-56D4-4796-8140-E7D550C0AB11.png (1.55 MiB) Viewed 1159 times
- 05BB5AB3-79B7-4C13-87AB-20F0842CB4F7.jpeg (448.08 KiB) Viewed 1159 times
- B77ABCFE-57B2-404C-8955-04CF314CE8CC.jpeg (253.26 KiB) Viewed 1159 times
Re: ENGINE STRETCH BRACKET
I have never heard of this 'Engine Stretch Bracket'
And can not tell from you pictures what it is - the red piece ? The piece outlined in green ?
So do not have a clue where you would buy one.
I’ll break it down, its not known here because we don’t really see people in US stretching scooter, mostly motorcycle.
First picture would be my end goal.. for my forza..
Second, would be original Bracket Engine Frame that’s already on your forza..
Third, Shock lowering kit. I already order this from bikerzbits, it’s to give the suspension a bit room for not hiting the air box.
Fourth ( my main problem finding it ) I attached 2 pictures from close and far distance. This goes after the BRACKET ENGINE FRAME TO THE ENGINE. To stretch the scooter.
https://www.hondapcx.org/viewtopic.php?f=21&t=2538
Check that link out, there a few short stretch of our scooter.
- Fourth
- 0CABF314-DBBE-4F3F-B087-2A1720389E6F.jpeg (253.26 KiB) Viewed 1126 times
- Fourth up close picture
- 83C1FDCC-FCCF-4DD9-BA9B-79FB69AEFEED.png (1.2 MiB) Viewed 1126 times
- Shock Lowering Kit
- 8E070542-6C23-4C37-87F1-0BFC2EA77326.jpeg (229.63 KiB) Viewed 1126 times
- Bracket Engine Frame
- 8F64A54F-E2DC-438B-82F6-783C35F5165A.png (113.22 KiB) Viewed 1126 times
- End GOAL
- 4630D4B4-B7FF-4B20-A522-D54427ED3019.jpeg (161.24 KiB) Viewed 1126 times
- Year: 18 300 xmax
There are several pictures on the Thai PCX sites of that shock lowering bracket in the back pulling rearward against the case and breaking the case. I’ll see if I can post a picture… I took mine off after I saw the pics…
- 581CDFD7-F71D-4434-8185-D0BBA3DAD0CE.jpeg (250.45 KiB) Viewed 1114 times
Now I get it.
That add-on bracket to move the shock toward the rear will act just like a lever, as the Thai PCX riders found out, and apply excess force on the belt case.
My view - stay away.
Ohhh well, too late for that. I already bought it and it wasn’t just $10
Oh if you sending me the link for the lowering profiler for the scooter, thank you but I already ordered one smile thank you again. I honestly need the engine bracket extension for the most part. Already tear the bike apart, just need that and custom air filter. I’ll update some pictures as soon I get it done
Check this one out, the one you sent me is not the same what I actually order. https://bikerzbits.com/forza-lowering-bracket.html <<< that’s an actual lowering kit..
The one you sent is a shock extension to make it higher I’m assuming.
UPDATE!! Found the guy that’s able to do it and a shop that sells it. first picture of the original second is the one with the extension.
- Original Engine Frame Bracket
- E8B4214F-2E6E-47D0-B4E9-143AA5BE29C9.jpeg (404.86 KiB) Viewed 1041 times
- With 3 inch extensions
- 30EDE5B1-33E0-41BC-BDDD-C14C9122DA87.jpeg (453.17 KiB) Viewed 1041 times
So you wanted a SWINGARM extension ?
That is what is pictured in the 2 pics above
That’s a swingarm for the forza..
The one I posted before is an engine bracket frame.
- 73503018-DAA1-4948-9CDB-5F1D81CCA9F5.png (410.62 KiB) Viewed 1034 times
