Tire recommendation?
Conelite
Color: Blue
Re: Tire recommendation?
Post by Conelite »
SantinoInc wrote: Mon Apr 19, 2021 12:50 pm Would you mind providing the exact sizes again and tell me where you purchased them from? You literally didn't even have to move the tire splash guards? Literally no alterations at all? I just got my bike but I'm very tempted to give these a shot!
Front Tire: 120/70-14
Rear tire: 140/70-14
City Grip Tires
ZERO mods. I heard that some people had to space out their mud shield but I just let it ride and it "self clearanced." :lol:
On a real note, the clearance of the guard and the tire was about an 1/8th of an inch. It doesnt hurt my feelings if it occasionally touches but Im 3k miles in with no issues at all.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
SantinoInc
Color: Gray
Post by SantinoInc »
Conelite wrote: Tue Apr 20, 2021 1:17 pm
City Grip Tires
You're the best man! Thanks so much for your time!
AC_ING
Year: 2018
Post by AC_ING »
Conelite wrote: Mon Apr 19, 2021 12:07 pm
The best thing about running bigger tires is stability. It gives you a larger footprint so it feels less sketchy at speed and it does not follow the road lines as easy. I highly recommend anyone with a PCX is to run larger tires than stock.
I will take that advice, thank you.
vamootsman
Post by vamootsman »
I run my front City Grip 120/70 at 23-ish psi and the the Rear 140/70 at 28-30-ish. Never run the same PSI in a higher volume tire mounted on the same rims on the same bike of the same weight. You don't do it on Motos, Cars or even bicycles. My mechanic put them up to normal specs and the bike handled like absolute garbage and rode even worse. If your on bad roads you may need more pressure to protect the rims but cornering will suffer. I've had them on for 3 seasons and few thousand miles and they handle and ride fantastic as set up. I weigh 190lbs kitted up.
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
dankly1
Color: Silver
Post by dankly1 »
I know this is an old thread, but I was looking at a tire sizing chart and it seems that 140/70-14 as a replacement for the 120/70-14 would not be the way to go. The 70 section on a 140 mm tire leads to a 1.1 inch taller tire with a 3.46 inch bigger circumference.
A 140/60-14 on the other hand is the exact same height and circumference as the 120/70-14. This gives a tire that is wider but without clearance issues with the bike.
For the front, I think the 120/70-14 is the best substitute for the stock 100/80-14. It is only .32 inch taller and has a 1.01 inch greater circumference. This is the closest option of any available size.
Bottom line: If you want wider tires but want to minimize clearance issues (and have a more accurate speedometer) then I recommend using 120/70-14 in the front and 140/60-14 in the rear.
Here's a link to the tire size calculator I used: https://www.discounttire.com/learn/tire ... MkEALw_wcB
Hope this helps someone! Cheers
Dankly
2019 PCX150
2013 Yamaha FJR1300
1983 Suzuki FA50
Iron Butt Association #80052
Hobbit112
Color: Gunmetal
Post by Hobbit112 »
This is the calculator I use:
https://www.tacomaworld.com/tirecalc
2019 Honda Click 125i
Yuminashi 164cc bore kit w/150 head
32mm throttle body and intake
13.5° SpeedTuner variator
15gr Dr. Pulley sliders
100/80-14(F), 120/80-14(R) Pirelli Angel Scooters
YSS front fork kit, YSS G-Series rear shock
op3l
Post by op3l »
Just thought I'd post this information. I had to get a new front tire yesterday and I tried to put on City Grip 2 100/90/14 and this tire is too tall to clear the front mud guard. It will rub against it. I ended up going with another front Angel Scooter 100/80/14 as they didn't have city grips in the 100/80/14 size.
So 100/90/14 for front on a 2018 PCX will not work.
