Retrofitting to European Lighting
pcx888
Color: pearl white
Re: Retrofitting to European Lighting
Post by pcx888 »
Gil wrote:Halogen light bulbs for the headlights, the rest are still LED.
I put all leds. no flickering on my end.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Gil
Post by Gil »
I think it was the LED headlight bulbs that I added that caused it, they had eight LEDs per bulb. Which ones did you use?
Also, good to hear that it was only on my end.
Gil
pcx888,
What was the bulb type you used for your main beams? The standard for 2011 - 2013 is HS5, which no longer comes in LED form. I would love to change mine to LED but I would have to change the base, plus find bulbs that fit in the wattage recommended (35/30).
pcx888
Color: pearl white
Post by pcx888 »
Mel46 wrote:pcx888,
Mel the headlamp assemble is now 119.00 on ebay with all cutout on the assembly. and uses 9003 bulb assembly.
Ebay item number is 303733963884.
2011 White PCX
