Tire size
Venom_Pcx
Tire size
Post by Venom_Pcx »
So I’ve seen a lot of posts about tires. But never a good explanation
I had ordered 120’ss for the front and was gonna do the 140’ss for the rear. But I want to know if that’s risky or not? Or should I stick to the oem size? Also has anyone changed they’re bars? And bar ends. ? Thanks :ugeek:
Re: Tire size
Venom_Pcx wrote:So I’ve seen a lot of posts about tires. But never a good explanation
Why do you want to move from OEM size?
Bar and bar ends are no more difficult than on any other bike. A pain can be the bar end screws though due to the threadlock compound. Properly fitting screwdriver and a whack with a hammer should sort that. Or an impact tool if you have one.
Re: Tire size
Pcx? I think there was a recent thread about the new tire size on the older bikes. The new rims won't fit the older bikes, and I think someone mentioned concern about the width of the new tire at the rim on the older rims. My suggestion would be, you can try them and let us know of any problems.
honkerman
Re: Tire size
Post by honkerman »
I've never felt a need for wider tires since Michelin City Grips work very well in the stock size; however, from what I've seen of other people's experiences, you're going to have some rubbing with the sizes you've referenced. some owners have safely gone up one width size on each tire without any major adjustments, but you still may need to take off the rear splash guard.
There's some crazy wheel and tire combinations that have been done on the PCX, all of which seem to come out of southeast Asia, including what look like thin mountain bike tires. Just the same, I still think the stock size is the best choice.
Re: Tire size
Welcome to our forums :P It's tires again. Who knew they would be in such demand. Anywho, lots to be found on the topic but when searching tires it's overwhelmed. That means a fail in finding your answer(s). Sorry, nature of the beast. Try a search in mother Google's search bar, there you'll be successful.
But wait....
Did you come upon this thread by any chance?
Take a look: viewtopic.php?f=2&t=8701
Now how about You do us a favor? Please take a moment to add your location to your profile. It helps us to help you now, and in the future. I have easy directions below my post to get'r done :P
Venom_Pcx
Re: Tire size
Post by Venom_Pcx »
WhiteNoise wrote:Welcome to our forums :P It's tires again. Who knew they would be in such demand. Anywho, lots to be found on the topic but when searching tires it's overwhelmed. That means a fail in finding your answer(s). Sorry, nature of the beast. Try a search in mother Google's search bar, there you'll be successful.
But wait....
Venom_Pcx
Re: Tire size
Post by Venom_Pcx »
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Re: Tire size
Post by alx123 »
Iv'e read that the OEM rim is narrow and attaching a wider tire will create a squeezing effect on tires and will actually reduce the contact area.
1 size up won't be a problem though..
big bear
Color: silver
Re: Tire size
Post by big bear »
when you replace your tires ive heard theres a rubber strip that needs to be replaced to on the rim ive only been riding for 2 years and still have my original tires. I dont even know if the pcx has this rubber strip
Re: Tire size
big bear wrote:when you replace your tires ive heard theres a rubber strip that needs to be replaced to on the rim ive only been riding for 2 years and still have my original tires. I dont even know if the pcx has this rubber strip
The rubber strip is a protector for spoked wheels to prevent the inner tubes from puncturing.
The PCX uses tubeless tyres on solid cast rims so does not need it.
big bear
Color: silver
Re: Tire size
Post by big bear »
good thanks
Conelite
Color: Blue
Re: Tire size
Post by Conelite »
Take it from someone running bigger tires. One of the best things I did. 140 rear 120 front(i think).
Speedo does read low but no big deal. Rides muuuuuch better and highway feels night and day.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Inoplanetyanin
Year: 2018
Color: WHITE
Re: Tire size
Post by Inoplanetyanin »
I think it's risky. Increases chance of crashing and getting killed. Also insurance would make a big deal out of you modifying the original tires so they might blame you for the damages.
No need to change tire sizes. OEM will stay in place whereas oversized ones are likely to come off under certain conditions.
You have to use the tire that the rim is made for.
Conelite
Color: Blue
Re: Tire size
Post by Conelite »
I think it's risky.
Unless you have experience with someone that has had this happen, Its not that big of a deal.
The tire wont come off the wheel if its inflated properly and installed correctly. I run my bike harder than most with ZERO issues. If you plan to keep the bike completely stock and rarely go over 60, stock size is fine.
Anything over that on stock size tires is much more dangerous. The stability of the bike with larger tires is night and day. Once you change the Variator 70+ is pretty easy, and stock tires at those speeds is horrible.
2017 PCX 150
Wirus Win Exhaust
Z-Bars
NCY Variator
Re: Tire size
HEAT applied to the very tip of the bar end helped it come out on my son's CB500X.
Conelite
Color: Blue
Re: Tire size
Post by Conelite »
Venom_Pcx wrote: Also has anyone changed they’re bars? And bar ends. ? Thanks :ugeek:
Yup.
Z-Bars went on easy.
2017 PCX 150
Wirus Win Exhaust
Z-Bars
NCY Variator
vamootsman
Re: Tire size
Post by vamootsman »
I have been running that tyre size for the last 2 years and it's one of the best changes you can make. You will need to adjust your air pressure accordingly as with more volume you need less psi. I typically run 28-30 in the rear and 25ish in the front unless I'm doing a lot of 2up riding then I add 3-5 psi. My bike handling with that and the new rear shocks is night and day better than with stock, and soooo much better for riding any long distances.
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
