LIGHTS
kjmillig
LIGHTS
Post by kjmillig »
WHo has changed from the standard 2 bulb headlight (2013) to a 6 light model? Is it worth the price?
Who has added light on the rear? What did you add?
Who has changed to constant and blinking turn signals/ tail light?
Gil
Re: LIGHTS
Post by Gil »
For the headlight I just drilled the appropriate holes for the corresponding light bulbs and installed the headlight harness from the UK model. As for turn signal LED retrofit, I bought the Amber LED lights on ebay of the appropriate socket type. I also used an LED compatible flasher relay from ebay. It was a dollar from China.
2-Pin Electronic LED Flasher Relay Fix For Car Motorcycle Turn Signal
https://ebay.us/FQqD1o
2x 1156 7506 BA15S High Power 50W LED 750LM Amber Yellow Turn Signal Light Bulb
https://ebay.us/uivVOe
Honda WW125 JF47 PCX125 2013 Front Headlight Wiring Harness Loom 531
https://ebay.us/WUZn6K
Re: LIGHTS
My 2013 bikes both have modified headlights and quite a few added tail lights. One of the lights that I added early was a light called a Knight Rider that moves back and forth until I press the brake lever. Then it blinks 5 5imes before going to steady on brake light. I also have lights on my tail bucket, tail rack, and even the mud flap...and the turn signals.
Connecting additional lights is not that difficult, but you do need to know which wires to connect to.
Rickjds
Year: 2020
Color: Candy Luster Re
Re: LIGHTS
Post by Rickjds »
Gil wrote:For the headlight I just drilled the appropriate holes for the corresponding light bulbs and installed the headlight harness from the UK model. As for turn signal LED retrofit, I bought the Amber LED lights on ebay of the appropriate socket type. I also used an LED compatible flasher relay from ebay. It was a dollar from China.
When not using the turn signals, do the turn signal light indicator stay on but dimmed when not flashing? This was a problem with changing the relay on the Suzuki Burgman.
Was this necessary and why?
