Adjustable Levers?
Drifter
Year: 13
Color: red
Adjustable Levers?
Post by Drifter »
Anybody got em, what do you think? I found a set on Fleebay for 25 bucks, that cheap i might give them a try.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Re: Adjustable Levers?
Post by SECoda »
I got the long ones. The shorter ones (which seem more common) are too short for my liking. Some more expensive ones have adjustable length too.
I have then as well. Mine also hinge 90° in case the bike gets laid down. It reduces the risk of breaking them. As far as price, it doesn't seem bad, but it also depends on the make/brand.
Sowaka
Year: 2013 PCX150
Post by Sowaka »
SECoda wrote:I got the long ones. The shorter ones (which seem more common) are too short for my liking. Some more expensive ones have adjustable length too.
http://i1211.photobucket.com/albums/cc430/tbln930/20140924_195102_zps2092bad2.jpg
These look to be the same ones I have. I find them to be pretty fantastic, though the mounting hole in one of them was a little bit too tiny for the special bolt on the bike, I had to buy a $6 chainsaw file and lightly file out the insides to prevent the lever from becoming "sticky" and sometimes not fully returning to the correct position.
Actually, come to think of it, with the ones I have you can't adjust them to the lowest setting without them impeding how hard you can squeeze the brake lever, they still work wonders, but if you adjust them to bring the lever too close then you're not going to be able to get 100% braking power.
You would have to adjust the brake cable if you wanted to keep the levers at the shortest distance setting. I had to adjust it for my wife's bike.
General question that might have alresdy been asked and answered: will the adjustable brake levers that fit a 2013 pcx fit the 2015 model as well?
Valiant
Post by Valiant »
They should. I got the ones SECoda has pictured.
The adjusting the brake cable is something that's a little tricky IMO. My front ones work fine, but the rear brakes only seem to work like stock at the maximum setting. I've tried adjusting the nut behind the transmission case, but tightening it anymore seems to result in the rear brake getting applied when I'm not squeezing the brake lever.
Valiant wrote:They should. I got the ones SECoda has pictured.
Same here
MikeP
Color: White /red
Post by MikeP »
Same here
I got similar ones to Secoda, made by bikers. Hesitated at first to buy, but after the install was surprised as to the nice responsive feel.
Took a bit to get the back brake adjusted, but by putting the bike on the center stand, adjusting the nut 1/2 turn at a time and checking the free spin each time I was able to get it quite tight.
pepito86
Post by pepito86 »
Is changing Levers something that a new rider who has never had a scooter or a bike before can do?
or is it necessary to get a mechanic to get it done?
pepito86
Post by pepito86 »
I know it is an old thread, but maybe I will get an answer
pepito86 wrote:I know it is an old thread, but maybe I will get an answer
It’s possibly the easiest thing you could do. Go for it and post some pictures.
X2
pepito86 wrote:Is changing Levers something that a new rider who has never had a scooter or a bike before can do?
If possible, take the stock lever with you when buying. Compare the hole size, location and the thickness of area around the hole.
Buying ebay can be a chinese crap shoot.
Folding levers are for a fall - don't fall. After a fall you'll have more concerns than brake levers.
Buy the non folding ones that don't have that extra movement beneath you fingers.
You can pay anywhere from $19 to $130 for a set.
These are on a Forza.
When I purchased the levers for both of my 2013 models I had never changed them before. It was easy enough, as long as you adjust the brake cable after you find out where the levers are most comfortable to you.
Venom_Pcx
Post by Venom_Pcx »
Can anyone please post a link? Thanks
https://smile.amazon.com/Short-Clutch-L ... 90&sr=8-22
Not the least expensive, but amazon has all sorts of accessories for a pcx.
Conelite
Color: Blue
Post by Conelite »
I bought the Amazon ones. Work great. Much better than the stock ones.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Color: 15 Forza
Post by 87112 »
Stock Forza and PCX levers are awful cheap feeling. I too bought the ones from Amazon
https://www.amazon.com/dp/B07JGV1L2B/re ... 313&sr=8-3
I do not know how some people are willing to pay over 100 bucks for levers. I can't tell those and these 32 dollars ones apart.
:geek:
Gil
Post by Gil »
Why do people install these? Do they have less play than the OEM ones?
