Pcx front fender noise vibrating while riding
I just bought Pcx 125cc 2015 and machine sound is very cool and smooth. But when I drive over bumps I heard noise like raffle or clicking or wiring in front of fender. Anyone how to fix it
- easyrider
- Color: blk
Re: Pcx front fender noise vibrating while riding
Sir, you first have to identify the cause before a repair can be administered. Plastic ties are handy when it comes to securing loose cables /wiring FYI
There is a collar that the wires usually run through in order to keep them from getting caught. You my be hearing the cables hitting that. You could also be hearing the brake cables hitting something under there. Look under the front wheel, up into the wheel well with a flashlight. If anything looks loose, or like it could bank up against something else, use some tie wraps to secure it to something else.
- PCX150Rider
Loose disc brake caliper?
Welcome to our forums would you please do us a favor too, by providing your location? Just Return to the user control panel and complete your profile. You can follow my easy directions right below my post.
We hope to help you as well. Thanks!
- PCX150Rider
Oh. . .check to see if you have anything rattling around in your glove box or in your under seat storage. Sunglasses, pens, coins, or anything that will knock around inside that glove compartment will make noise. Think of it as a tapping on plastic noise. Empty the glove box and under seat storage area, take it for a ride, and see if the noise goes away. Just a guess.
And yes. . .if you would be so kind as to let us know where on the planet you exist that would be great.
