It is currently Sun Jan 21, 2018 10:55 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
PostPosted: Fri Aug 11, 2017 4:05 pm
Offline
Color: white/blue
Hi
I need a new Battery for my Forza.The O.E.M is rather expencive with 77£.
Can anyone recommend a cheaper option,Iam in UK.
Thank you.
Top
 Profile
PostPosted: Sat Aug 12, 2017 1:33 am
Offline
Color: Silver
Hi Rollmops
Has your battery died? Mine died as a result of the harness issue, however my local Honda dealer fitted a new battery foc before I had the replacement harness replaced, however they did recommend a battery charger/ maintainer which I duly purchased ( Oxford maximiser 3000 I think) bit expensive at £70 but well worth it, every time I put the bike in the garage it goes on charge.
If you've not had the replacement harness I'd book it in as its free of charge but might take a couple of days to fit.
Regards
Drew
_________________
Forza 125, 15 plate, top box, hand guards, grip puppy's,Givi screen, malossi variator, belt, clutch bell, carbon belt,city grips,BMC air filter.
Top
 Profile
PostPosted: Sat Aug 12, 2017 2:24 am
Offline
Location: Lying in the gutter in the centre of the universe
rollmops wrote:
Hi
Thank you.
eBay?
_________________
Flu based abstinence
Top
 Profile
PostPosted: Sat Aug 12, 2017 9:18 am
Offline
Color: white/blue
you you wrote:
rollmops wrote:
Hi
Thank you.
eBay?
Nope..its even more expensive.
Cheapest i found
Code:
http://www.wemoto.com/bikes/honda/nss_125_forza/15/picture/battery_oem/
Top
 Profile
PostPosted: Sat Aug 12, 2017 9:40 am
Offline
Color: white/blue
V8vor wrote:
Hi Rollmops
Regards
Drew
My Battery is still OK, sort of.It does take a few more turns to start, but then after over2 years no surprise. It will be getting colder soon and my bike is parked in the street.Charging the battery all the time is not really an option.
I get a new Battery and keep the old one charged as a backup.
My harness has been replaced,so no issues there.
Top
 Profile
PostPosted: Sat Aug 12, 2017 9:29 pm
Offline
Year: SV650AL7
Color: The correct one
According to this its a Yuasa YTZ8V
According to this chart the YTX7L-BS battery is a very close match and should do the job.
Battery2u list the YTX7L-BS as the one for the job and it can be had for much cheapness elsewhere.
The one aspect the cheaper YTX7L-BS battery doesn't match is the CCA (cold crank amps) rating, however that's only likely to be a problem in extreme cold when you probably won't be using the scooter anyway.
_________________
Top
 Profile
PostPosted: Sun Oct 29, 2017 9:01 am
Offline
Powered by angry squirrels
Color: PearlDrkAshBlue
DO NOT let your battery run down! We have this issue on the Honda Fury, where the battery and charging system are "undersized" from Hong just to get them to fit. The starter draws a constant amount of power, like any electronic motor, so the less voltage supplied the more current (which is why you're not supposed to run an air compressair at the end of an extension cord). The higher current draw heats up the starter windings and brakes down the insulation, resulting in a weaker starter that draws more current, until the starter needs to be replaced. Fury owners have such an issue that those unable/unwilling to use a top-end battery maintainer are buying lithium batteries--if you think glass-mat batteries are expensive, try those!
Anyway, for low prices head to the tractor supply store. Lead-based batteries should be around $30, AGM almost twice that price, and lithium around 5x the AGM price. Each commands the price for a reason, BatteryUniversity.com lays out the differences.
I think, "buy quality, buy once, have few problems, lower Total Cost of Ownership." Yes, I've had to give up that extra pint at the pub on occasion, but I always make it to work without issue thanks to not being pissed (drunk) and having a vehicle that runs like a top (runs well) (so no lost income).
I found a top-end battery maintainer (BatterMinder) and AGM batteries in the bikes works great. Not inexpensive, but lower TCO than other methods, keeping th' most coin in me pockets. Now that's kind of a spendy date, so I built meself a power distribution center with fuses (that illuminate when blown) and such, SAE connectors, the works, but one can buy a 4 or 6 connector Y-harness and simply rely on the fuse on the machine. (I pull batteries out of some vehicles so did it differently).
Whatever works best for your situation... PM me if you have questions, always happy to lend a hand.
Top
 Profile
PostPosted: Sun Oct 29, 2017 9:35 am
Online
Year: 2015 PCX
I can’t stand battery problems, so mine is replaced every two years whether it needs or not. They’re cheap here in the US.The old battery comes out , and goes on my bench as a 12V source for projects.…
_________________
Glen in Fort Lauderdale
My build thread here:
http://www.hondapcx.org/viewtopic.php?f=2&t=4640
‘15 PCX
‘16 CTX 700 DCT/ABS
Top
 Profile
Who is online
Search for:
Jump to:
