12V SOCKET
Duke82
12V SOCKET
Post by Duke82 »
Hi all, a bit embarrassed about this question but here goes.
Can i hard wire a 12v socket to the battery? i have done this on every motorbike i've ever had but i have no idea how the stop start system on the pcx works and wasnt sure if there is a conflict. it will be an always on socket with no LEDs, hasnt drained batteries in the past.
This is just for my heated jacket as it needs a 7amp fuse and the stock pcx socket is only 1 amp
cheers
easyrider
Color: blk
Re: 12V SOCKET
Post by easyrider »
Of course you can. Just connect your neg and positive to the respective battery terminals. Be sure to install a fuse (holder) on the red + side. All is Ok no interference.
Duke82
Re: 12V SOCKET
Post by Duke82 »
Fantastic. Cheers!
montliz44
Year: 2013,2014
Color: red+redder
Re: 12V SOCKET
Post by montliz44 »
You can buy all these parts from Battery Tender. That's the way I get power for my jacket : The basic Battery Tender permanent hookup to the battery and the removable Battery Tender "cigarette lighter" attachment connected to the permanent hookup. Works great -- the fuse is already in the permanent hookup and the only time you draw power is when you have your jacket plugged in. Plus you now have your battery tender lead right there for charging your battery if you need to. On my PCX I drilled a little hole in the black plastic just above my fuel door for the battery tender lead to exit the battery area.
Johnny
Re: 12V SOCKET
I set mine up by running the Battery Tender wires through the seat hinge. That way I didn't have to drill any holes in the plastics. The adapter comes with a protective cap, so it is safe when not using it.
https://www.amazon.com/Battery-Tender-0 ... nder+cable
Or
https://www.amazon.com/MOTOPOWER-MP6899 ... 4W8DWTNKEF
TheMaverick
Re: 12V SOCKET
Post by TheMaverick »
Just a thought - will the PCX alternator be able to keep up?
Re: 12V SOCKET
TheMaverick wrote:Just a thought - will the PCX alternator be able to keep up?
Should do, it's attached to the bike.
montliz44
Year: 2013,2014
Color: red+redder
Re: 12V SOCKET
Post by montliz44 »
You you is right (again) !
But seriously, folks, mine has worked for three winters with no problems and I still have the original battery.
Johnny
Smaug
Year: 2013 PCX150
Re: 12V SOCKET
Post by Smaug »
That's not necessarily true. If the heated jacket draws more current than the alternator can supply, you'll be draining the battery just to run the vest.
Also, are you guys using those full-size automotive jacks? They're kind of big for a scooter. I'd be tempted to just rewire the accessory to use a Battery Tender plug. The alternators are rated 343 W. 343 ÷ 12 V = 28 A max, or 25 A @ 13.8 V. Subtract the load for the headlights (50 W --> 3.6 A or so) and leave enough to keep the battery charged. Figure you have maybe 10-15 A to play with.
-Jeremy
Re: 12V SOCKET
"Figure you have maybe 10-15 A to play with."
Except when they don't want to play. Ever seen a runaway amp? They have no intention of ever playing. Funny things, those amps. They can be good until someone opens the gate. Then they go to ground, and then you have a heck of a time finding them. :-/
Re: 12V SOCKET
Biting tongue. :roll:
