Newly installed Rotor disc and pass switch....
- Color: gray
Newly installed Rotor disc and Pass switch
- pcx2.jpg (114.43 KiB) Viewed 2647 times
- pcx1.jpg (73.48 KiB) Viewed 2647 times
- pcx.jpg (126.4 KiB) Viewed 2647 times
Re: Newly installed Rotor disc and pass switch....
DAHAM, smack down, BOOM! that's BEAUTIFUL! You must look like a turd when you sit on it because what could one possibly wear to compete with that? No bag of blood and was is worthy to mount that bike.
Hey choice cuz, that's not a bad looking rotor, where'd you score that from? Is it 220mm, still?
- Color: gray
the size is the same with the stock rotor, i bought it from Philippines..chicaboo wrote:Hey choice cuz, that's not a bad looking rotor, where'd you score that from? Is it 220mm, still?
- Color: gray
at least i'll only look like a turd when I sit on it, while you look like a turd all the time..hahahaahaahomie wrote:DAHAM, smack down, BOOM! that's BEAUTIFUL! You must look like a turd when you sit on it because what could one possibly wear to compete with that? No bag of blood and was is worthy to mount that bike.
We have a Winner!
Wait....was there a contest?
No? Okay whatever. Let's make believe.
WINNER!!! This scoot's a Beauty! Mixing colors, Well Done!
touchéjhongskiecruz wrote:at least i'll only look like a turd when I sit on it, while you look like a turd all the time..hahahaahaahomie wrote:DAHAM, smack down, BOOM! that's BEAUTIFUL! You must look like a turd when you sit on it because what could one possibly wear to compete with that? No bag of blood and was is worthy to mount that bike.
I'm curios about the humped seat on a 2015 PCX. How did you manage to get one with a hump to fit the LED bike?
That is definitely a 2013 model, but it also definitely looks nice.
Perhaps one of the rare 2014 transition models?Mel46 wrote:That is definitely a 2013 model, but it also definitely looks nice.
- Year: 2012
the rotor installed wrong direction, isn't it?
It would seem that wave rotor is installed backwards... ouch!Vancho wrote:the rotor installed wrong direction, isn't it?
Pads will be destroyed in no time right? Didn't know you could do that, learned me something here today about wave rotors.
His braking effort should be better at the cost of pad material I guess? If it doesn't shudder.
Probably much of a muchness...
No funny transition models, that's an OWL. Just +1 the year on everything in America.
- ItBeMe
- Color: Very dark blue
Why do you call your Hi Low beam switch a Pass switch. Mine does not have the words Pass on mine.
His switch has a 3 way rocker instead of a 2 way rocker.ItBeMe wrote:Why do you call your Hi Low beam switch a Pass switch. Mine does not have the words Pass on mine.
There is an extra momentary switch that if you flick down will briefly flash the highbeam.
This is known as a pass(ing) switch, and is more common on motorcycles.
jhongskiecruz .... you mad bro?
We've all been there, you would rather know than not know about the wave rotor i'm sure. Come on back and tell how it's possible the rotor is reversible and were there no instruction with the purchase. This might be too easy to do for any of us.
- ItBeMe
Dam mine is only a 2 way. I wish it was a 3 way.chicaboo wrote:His switch has a 3 way rocker instead of a 2 way rocker.ItBeMe wrote:Why do you call your Hi Low beam switch a Pass switch. Mine does not have the words Pass on mine.
