Top speed of a forza
Russpuss
Post by Russpuss »
I've recently bought a new forza. After running it in I've found my top speed to be barely 130 kph. Reading all the other reports about top speed, mine seem to be well behind. Can anyone shine some light has to why?
Re: Top speed of a forza
Find a longer road.
It takes a long while to get up to max speed.
Russpuss
Post by Russpuss »
Lol. I think the road from Korat to Pattaya is quite long.......
I do realise when A bike won't go any faster after full throttle mile after mile. The main reason for the question is, has I was looking at different Honda shop. One sales woman told me the new forza have been governed. Does anyone know this to be true?
Ah, you're in Thailand.
Atmospheric conditions might be against you.
Hot weather = less power.
Never believe salesmen. Or women.
easyrider
Color: blk
Post by easyrider »
gn2 wrote:Ah, you're in Thailand.
or politicians, and weatherman !
davenowherejones
Color: Silver
Post by davenowherejones »
Forza 300 top speed is determined by wind speed. Find a long road with a big tailwind and you will go faster. Hide behind the windshield to go faster. 148 kmph indicated was my fastest when new downwind. Now I barely make 130 kmph.
The suspension is too primitive to be doing this. Tires too small. And with age comes wisdom followed shortly by senility.
davenowherejones wrote:Forza 300 top speed is determined by wind speed. Find a long road with a big tailwind and you will go faster. Hide behind the windshield to go faster.
:lol: don't forget downhill... downhill with a tailwind behind the windscreen with a loaded top box :lol: It's a JET!!!
Russpuss
Post by Russpuss »
What's that old saying. Ask a stupid question and get a stupid answer lol
stryder123
Year: 2014 forza
Post by stryder123 »
I have a tall windscreen and weigh about 113 kg. I find under normal conditions my Forza tops out at 130 also
Presuming you've checked the tyre pressures and that the brakes aren't binding?
PingGam
Year: 2012 PCX
Post by PingGam »
Russpuss wrote:I've recently bought a new forza. After running it in I've found my top speed to be barely 130 kph. Reading all the other reports about top speed, mine seem to be well behind. Can anyone shine some light has to why?
The maximum speed limit is 120 kph on an expressway, so why go faster? ;)
Current Scooters
2012 PCX 150 Black
2016 Forza 300 ABS Yellow
chicaboo
Post by chicaboo »
A higher max speed is typically indicative of better acceleration up to the posted speed limit.
Without testing it with a GPS, he may only be doing 120kph and not actually even making it to 130, anyhow?
Flybywyre
Color: Silver
Post by Flybywyre »
Mine sits happily on the motorway at 75/80 mph and it will do 85 mph if required.
However it is a bit susceptible to road imperfections at higher speeds, especially when crossing white lines to get back into a slower lane.
I would strongly advise not to do those speeds with a loaded top box on.
I have a 45 ltr top box and the advised speed limit is 130kph and the maximum weight of the loaded top box should not exceed 10kg.
With the top box on and at speed the front end becomes quite light, you need to be very careful when overtaking a lorry.
I often do long trips with a fully loaded top box and find it is best to keep below 70mph if you can, which sometimes I can't :o
davenowherejones
Color: Silver
10 kg for the top box does not sound like much. I need to weigh my groceries next time. I think that includes the 55 litre top box as well. 4 litres of milk is probably 4 kg, the case is 5 kg, so that leaves 1 kg for bananas and potato chips.
I never follow the rules anyway. Load it up.
I need to do a speed run with and without the top case. I should also do one naked.
davenowherejones wrote:10 kg for the top box does not sound like much. I need to weigh my groceries next time. I think that includes the 55 litre top box as well. 4 litres of milk is probably 4 kg, the case is 5 kg, so that leaves 1 kg for bananas and potato chips.
No dont :lol:
davenowherejones
Color: Silver
But Billy Connolly does it.
dam fast until you push LOL
gn2,
You're a caution!
davenowherejones wrote:But Billy Connolly does it.
That's not an excuse. We've had 40 years of the unfunny dullard over here. Don't copy him.
Mind you, where would you be without yer wellies :lol:
