I don't need the Kitaco gear-up kit if that's what you mean? Aussie KF12s are already the fastest in the business!k2apache6.0 wrote:I guess I'm too mentally lazy to 'choose' my parts. I just want them (yuminashi) to have done all that for me already, just send me the whole part, TB, Manifold, and whatever else, already researched, just bolt it on and go lol. If I get about 3 more horses with a fairly flat power delivery I'll be happy. I know I'll probably need the Kitaco gear up kit too to get any more topend speed, I take it you've already aquired one of those? I definately dont want to have to buy AFR meters and such, stuff I'll likely never use again. Probably all I'd likely do is have it dyno'd on completion and overlay the graph onto the stock 150 graph. Hopefully it won't lose anywhere and gain most places, especially after about 6,000 rpm in view of the Yoshi pipe I already have. In that other thread the guy who just did a BBK for someone said the guy said he wanted ,smooth'. That represents my attitude pretty well too. Smooth and safe (for the engine) with good fuel metering.
I'm already geared to an indicated 130kph stock, and can extend that beyond 150kph+ with my Daytona variator.
So I can artificially keep the scooter away from the rev-limit if I want to save fuel or whatever else.
So you know, my scoot pretty much sits on 6000-7000rpm when cruising with the 13g sliders (speed dependant).
When I kick it in the guts, the variator picks up to almost 7500rpm under hard acceleration, and goes from there.
All these stats change as I make more power. But I can make changes with the 11g sliders or 14g Daytona rollers.
I'm expecting to have a pretty smooth setup with what I've got. It's only getting the mild Takegawa cam with the BBK.
I've not lightened the mass on the flywheel or the clutch/bell, so I won't have any unexpected hardships putting around.
The only drive changes I may need to make are a firmer contra spring or sports oriented driven pulley for acceleration.
