STANDALONE ECU FOR PCX125/150 LED MODELS
BPT7594
Post by BPT7594 »
Let me get straight into the point.
We have perfected the standalone ECU for the PCX125/150 LED models. Wiring is the same from both models, I've checked. Brand is familiar, APITech.
Let me explain a little. The problem with making a standalone for the PCX125/150 is that the stock ECM handles both starting and recharging the battery. Therefore, you cannot completely drop it. APITech went the other way, it will let the ECM start the engine and recharge battery, but that's the end. Everything else is fully controlled by this 9.0 APITech standalone. Which would mean that you have complete control over your engine's behaviour. I don't know about you guys but I would choose a standalone over a piggyback any day.
The picture is from my friend's PCX125 LED, with a Char Mo 61mm piston kit, stock camshaft, Forza 300 exhaust, 31mm TB, CBR150 injector with the standalone installed. The difference between tuned and no tuned by the standalone is like night and day. One thing that is amazing about this is the fact that it can control the injection timing too. Which means that if you are smart enough to know when the intake valve opens on a certain crankshaft degree, you can change it so that the fuel is sprayed exactly during the intake valve opening duration or so. Remember, since it is a standalone, it has full control of everything.
Screen Shot 2017-01-21 at 6.52.33.png (1.46 MiB) Viewed 3086 times
BPT7594
Re: STANDALONE ECU FOR PCX125/150 LED MODELS
Post by BPT7594 »
Price for 1 model will be around 200USD (that is included shipping to your exact location).
And yes I am selling it, but I do not have a lot of stock, since (1) it is just been out of development and officially in use and (2) I don't have a lot of money to stock it. For those of you who have doubts about me, I've dealt with Oyabun and that adam guy from Israel.
Send me a pm or e-mail bachphamthien@gmail.com. I will try to answer as fast as I can but please understand that I have 3 bikes on my hands currently so I may be a little slower than you want me to be to reply.
Gil
Post by Gil »
Could this ecu be able to control a turbo engine. Does have control over ignition timing?
Gil
chicaboo
Post by chicaboo »
Nothing for the OWL?
BPT7594
Post by BPT7594 »
Gil wrote:Could this ecu be able to control a turbo engine. Does have control over ignition timing?
Gil
Full control over ignition timing at every TPS and RPM range.
Turbo? If you know how much fuel you need to compensate for the added air sure.
BPT7594
Post by BPT7594 »
chicaboo wrote:Nothing for the OWL?
If you have the wiring diagram for your scooter, send it to me and I will work out a wire harness for you.
chicaboo
Post by chicaboo »
I'll email you the wiring diagram later.
BPT7594
Post by BPT7594 »
chicaboo wrote:I'll email you the wiring diagram later.
I saw the wiring diagram for your scooter. It is problematic.
Because your scooter uses 21 pin and 12 pin connector not 33 pin. I don't think I have the male and female for those 21 12 pins lol. Guess you're out of luck. I'd need to ask my guy first.
chicaboo
Post by chicaboo »
It's no problem for now. Who knows, my Dobeck EJK may work out as a long term solution?
BPT7594
Post by BPT7594 »
chicaboo wrote:It's no problem for now. Who knows, my Dobeck EJK may work out as a long term solution?
Since I found out about this standalone, anything other than a standalone is strictly short term, except for those guys with scooter that has the 21 pin ECM. Those guys with the 33 pin ECM will eventually find their way to a standalone because let's be honest, a piggyback will never be as stable as a standalone.
chicaboo
Post by chicaboo »
Someone has to make it first... :(
BPT7594
Post by BPT7594 »
Well I did it first for the pcx125 led
I'm planning to make the wire harness for all other esp lines pretty soon.
chicaboo
Post by chicaboo »
Are you collecting base maps from your friends as you go?
BPT7594
Post by BPT7594 »
I can make a cfg file I think.
But as usual, no 2 bikes are alike. Because I use different variator compared to yours, that means different load. That means different fuel adjustments.
chicaboo
Post by chicaboo »
I think ballpark within 10% of average would be fine, just so someone can start the engine.
BPT7594
Post by BPT7594 »
The base map is for a stock pcx150 led.
After a few days the standalone is working perfectly. Still needs some adjustments to the enrichment system after cold starting but overall perfect.
Let me state again that a piggyback will never be stable as a standalone. You cannot control the ecu 100%. But if that's what you have then well we must accept it then.
chicaboo
Post by chicaboo »
I don't even have a piggyback, I've just got a fuel interceptor.
There's a reason why I didn't buy a piggyback right now.
There's the APItech you're adapting, and something else on the horizon.
BPT7594
Post by BPT7594 »
I don't know what an interceptor is.
If it's some sort of resistor to change the injector pulse width it will be interpreted as a faulty injector by the ECU if you change it too far. The owner of the bike in the picture used a Takegawa controller in the past. Runs funny as shit. It runs 1 way during a rain, 1 way in the morning, 1 way in the afternoon, 1 way in the evening. All with the same setting. Hence the need for that standalone.
chicaboo
Post by chicaboo »
For an interceptor you have to disconnect the stock EGO and then it reduces flow to the injector with resistance, yes.
The Jaycar interceptor I made was much more versatile, also being able to offset the signal from an EGO, like the WB2 & LC2 do.
Unfortunately it's gone missing, so I took a punt on the cheapest thing available to tide me over. The Honda CB/CRF guys love the Dobeck...
