31MM THROTTLE BODY SET FOR PCX125 LED & PCX150 LED
YUMINASHI
Post by YUMINASHI »
We received a lot of questions why it isn't possible to install a 31mm throttle body on the new PCX125 LED or PCX150 LED and the answer to this question is because Honda have indeed still the same 5-pin connector on the wire harness, but they changed the connection with the MAP, IAT and TP sensors.
Honda also decided that the throttle cable must be different with the new LED bikes for a unknown reason, so you can't use your stock throttle cable on the 31mm or 35mm throttle body anymore.
So this is just a heads up that we have worked a new set out which covers the issues to make the install possible, and this set can be ordered from now on on the Direct Sales website from Yuminashi.
The product page can be found over here: http://www.yuminashi.eu/31mm-throttle-b ... rrencyId=2...
