My pcx 2016 dyno stock vs malossi variator
- Color: Blue
Here is a graph for my bike
Blue stock
Green malossi variator
Red malossi variator + malossi belt
Blue stock
- IMG_5242.PNG (1.37 MiB) Viewed 2458 times
- Color: Blue
Re: My pcx 2016 dyno stock vs malossi variator
More to come i have some ehxaust to
Test in these couples of weeks
Akra and take
Akra and take
So folks understand
A Honda Grom gets 8.96 Horse Power @ 8750 RPM
I get 92 hp @ 7500 RPM on a stock Buell
subscribe and see all specs on many popular bikes
https://www.youtube.com/playlist?list=P ... D74057DC0E
Power at the wheel is only about 75-80% of what the engine actually makes...
Another rough estimation that appears to work on the PCX is engine kW = wheel HP.
A Grom won't see even 8HP on a dyno in stock form.
chicaboo wrote:A Grom won't see even 8HP on a dyno in stock form.
Grom Dyno
https://www.youtube.com/watch?v=DRDueDa ... 0E&index=4
I was thinking in kW, but wrote HP. Still, chains don't rob much power compared to a CVT!homie wrote:chicaboo wrote:A Grom won't see even 8HP on a dyno in stock form.
Grom Dyno
- Color: Blue
My grom did around 22 hp with take 4v kit and 34mm TB
Stock around 8
12 to 13 hp with take 2v kit
graph below for a take 2v vs take 4v w/o
34mm TB
Stock around 8
34mm TB
- IMG_5286.JPG (96.59 KiB) Viewed 2419 times
- Oyabun
- Year: `12,`15,`19
- Color: black&black
Sam, have you ran the 183cc big bore 4v kit? What injector?
- Color: Blue
I ran the 181 take 4v with the injector that comes witht the kit
Part number 00-00-0487
To be uses the 34mm throttle body
Any help regarding takegawa products
Or grom or pcx let me know
RE: published dynos of PCX on this page: What model pcx? 125/150 ? . You mentioned 2016 so it should be the led model, please confirm, thanks
- Color: Blue
Yea its led model with key less
150cc
Any more info let me know
150cc
- Color: gorgeous white
great insight. does the malossi kit make the scoot better on the freeway? does it sacrifice anything - fuel consumption, belt wear etc?
- Color: Blue
It went up from 120 to 130 top speed
Same fuel consumption even less
No issue with the belt or any thing
Great mode to do
Great mode to do
- vamootsman
Is that 130kph on the road, or on the center stand? If on the road, how, when your producing less hp that a stock 2013 pcx150 according to the dyno in your attachment.
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
- Color: Blue
On the road or on the stand both it will hit 130klm on the odometer
With the malossi variator you will gain low end power till around 70 klm
Then it hold the same power but with more top speed
You lose a bit of power on top with the belt only around 1/2 hp
I didnt dyno any pcx 150 2013
Only 2016
Only 2016
The dyno reads power at the wheel, not the engine. With a CVT you lose lots of power to the wheel compared to a chain drive.vamootsman wrote:Is that 130kph on the road, or on the center stand? If on the road, how, when your producing less hp that a stock 2013 pcx150 according to the dyno in your attachment.
Is it still comfortable to ride slowly under 60kmh?
Sam,
What i miss here is Rpm reading and torque figures- that would be useful. Please ask to see them when you redo a dyno with exhausts
Best,
Best,
- vamootsman
chicaboo wrote:The dyno reads power at the wheel, not the engine. With a CVT you lose lots of power to the wheel compared to a chain drive.vamootsman wrote:Is that 130kph on the road, or on the center stand? If on the road, how, when your producing less hp that a stock 2013 pcx150 according to the dyno in your attachment.
I don't see anything about engine modifications, so unless there are some, the stock hp should be roughly the same, and would still beg the question of how that's possible, unless the bike is going downhill with a tailwind.
2013 PCX 150 with,
The stock HP is roughly the same, all about 10HP. But because the engine power is going through a CVT it changes the shape of the power delivery (and gearing), hence why the flatspot from 30-70kph is removed with a higher top speed with the new variator.vamootsman wrote:chicaboo wrote:The dyno reads power at the wheel, not the engine. With a CVT you lose lots of power to the wheel compared to a chain drive.vamootsman wrote:Is that 130kph on the road, or on the center stand? If on the road, how, when your producing less hp that a stock 2013 pcx150 according to the dyno in your attachment.
You can also remove this flatspot with lighter rollers or sliders, but with very little to no change in overall gearing like with a variator swap.
The only way to see true HP at the wheel on a dyno is to lock the variator so the belt can't ride up it as the engine speed increases.
You would also need to clamp the spark plug to get a RPM reading, and then you can see the real shape of the power delivery.
But this graph is fine to me, as it shows you real road performance through the transmission, which on a scooter is more meaningful.
