windshield removal
Posted: Tue Sep 19, 2017 6:45 am
by Jacito
How difficult is it to replace the OEM windshield on a 2015 PCX-150 with something taller? Currently the wind hits me squarely in the chest. BTW, I'm 5'-10" (178cm) tall.
Re: windshield removal
Posted: Tue Sep 19, 2017 7:02 am
by BobS
Very easy to install
Take a look here -
http://www.hondapcx.org/viewtopic.php?f=3&t=7278
Lots of posts about which is the best windshield for your height
Posted: Tue Sep 19, 2017 8:28 am
by Jge64
Two screws, a few 10mm bolts, 10 min swap.....
Posted: Tue Sep 19, 2017 9:27 am
I have a 2013 model, which is a little different, but I have changed out windshields many times. There is much to it. First I removed the trim that covers up the 4 bolts that hold the windshield on. The trim is held on by two screws and some clips. After that, it is easy...just remove the bolts. That's it. Put it back together in reverse order.
So, just find the windshield you want, and then just go for it.
Posted: Sat Oct 21, 2017 3:40 pm
by pendulum
Something that stumped me for a bit was how to remove that front trim piece without breaking it.
After you remove those two screws you want to slide the trim piece down. Do not pry it upward or outward.
After you do it the first time, it's a 10 minute job. And I'm sure more than a handful of us switch screens for seasons too. ;-)
Good luck!
