National Cycle windshield
- NADman
Has anyone had any experience with this windshield?
They say it's 16.5 inches 'vertical' from top of stock headlight shroud.
I'm thinking it won't come near covering my face.
The Givi 323DT is only an extra $30.00 but with the weird shape, can it be cut down a few inches if needed?
https://fortnine.ca/en/national-cycle-r ... ted-n20052
- gbru2505
- Color: Carbon Grey
Re: National Cycle windshield
THere's a conversation going on here:
http://www.hondapcx.org/viewtopic.php?f ... 20#p120268
about the tall Givi on the PCX 125.
I've just had a D1130ST installed which goes to my chin. The problem is that you get lower pressure behind the screen, so air rushes in from the sides to fill the void, which causes loud buffeting against the helmet. Buffeting wind is much louder and has a physical, unsteady knocking quality to it that my ear plugs are now almost useless against when it is bad. I would now go for the smaller Givi aiming to lower the wind and rain on my midriff and chest, but leaving the air flow steadily over my helmet which I would tackle with earplugs. I ride all year though, so I'm leaving it on until next winter and I'll consider a better helmet and muffs in the meantime. I wear a flip up, open in summer, and it's catching the air really badly. I don't think a taller screen would be any better, There'd still be a vacuum drawing in buffeting/knocking air.
G'Bru
- Eiron
- Color: Poseidon Black
I have the Honda OEM "Tall" windshield and it measures 27" from bottom to top, and it looks shorter than the one in the NC photo.
I'm 5'9" and the Honda windshield comes up just below my eyes. Wind is a non-issue for me because I'm always wearing a full-face helmet.
As far as I know, only Honda and NC make their windshields out of polycarbonate. I wouldn't buy a windshield made from acrylic because it's not shatterproof. But that's me.
Try this link: https://www.nationalcycle.com/catalog/c ... ew/id/4528
It shows where they're measuring from.
- Honda OEM Tall windshield
- 08r70k35j00.jpg (94.7 KiB) Viewed 1502 times
- Eiron
Using NC's measuring method the Honda "Tall" windshield measures only 12" above the headlight shroud.
P.S. to the mods:
Is there any way to lengthen the edit time on posts? It's frustratingly short!
P.S. to the mods:
- Eiron
I was wrong on this. The Honda Tall windscreen comes up just below my nose, and the air coming off the top of the screen hits me right in the eyes. Sorry for the previous incorrect info.Eiron wrote:I'm 5'9" and the Honda windshield comes up just below my eyes.
The tall NC windscreen would've been a better choice for me if it had been available.
- gbru2505
Interesting photo. The Honda screen appears to mount very differently to my tall Givi. It looks like there is a deep gap across the entire base of the screen there for airflow (and pressure balance?). My tall Givi is fixed tight to the bodywork, with only a narrow gap the size of the bodywork recess at the lowest point. Would that be right - is the Honda screen mounted away from the bodywork for airflow?Eiron wrote:I have the Honda OEM "Tall" windshield and it measures 27"
G'Bru
- Eiron
Yes, you're absolutely correct. My 2015 screen is shaped a bit differently from the one in the stock photo (the nose is rounded longer/closer to the bodywork), but there's 1/2" gap along the edges, a 3/4" gap lifted off the bodywork at the front, and 1" of reach/space from the lowest point of the screen to the contour cut in the bodywork.
- P6019990.JPG (332.7 KiB) Viewed 1432 times
- P6019994.JPG (382.3 KiB) Viewed 1432 times
- gbru2505
Thanks Eiron. Think I'll have to look at ways to remount my tall Givi to create more airflow behind the screen / balance the air pressure better and in the hope that it'd reduce buffeting I'm getting around the front of my helmet.
G'Bru
I've had the National cycle screen on my 2013 model for about 3 years after I wrecked and broke my tall givi screen. I do like it. It is a bit shorter than the tallest givi screen but not much. I'm about 6ft tall and can see over the top. I'd guess the top of the screen comes to my chin. Air flow hits me right above the eyebrows. Like someone else said there is a fair amount of air turbulence around the screen and it does cause some noise, but not too much. The ride is much more comfortable at highway speeds. I don't feel like I'm being pushed off the bike at 60mph. The real difference between the taller givi and this screen is air flow. I got less air flow with the taller givi screen and on hot days I would get hotter while riding. It's a real balance of comfort preferences. The screen has held up well to bugs, rocks, and road dirt. It looks good and installs easily, although I did have to add some plastic washers to tighten down the screen on the bike. Otherwise it would have been a little loose and would have rattled in the wind. I've occasionally gone back to my original honda screen (no screen) and hate it. So any wind screen is better than none .
- 20180610_122343.jpg (154.62 KiB) Viewed 1348 times
- Year: TBD
- Color: TBD
Anyone 6'2 and has the tall windshield? If yes does it cover you completely?
- NADman
I just installed the National Cycle 'tall' windshield but only have a couple of miles on it.
I'm 5'11" and while riding I see over it to about 25 ft in front of me. Has the 'curls' on each side
and there quite a bit of room for airflow at the bottom front.
Will give another evaluation when Dr. says its OK to ride.
- IMG_0735.JPG (87.32 KiB) Viewed 1222 times
- IMG_0734.JPG (85.4 KiB) Viewed 1222 times
- Testerpt5
- Color: Black matte
I am 5' 9 (180cm) and I have the tall windshield, the only complai t is that is still not tall enough, a few more cm and I would not get wind into the helmet and consequent noise, other than that I amvery happy specially in rainy days, bugs and very hot days, the other day was 45.5°C (114°F) and it really helped!
I have the tallest Givi windshield for my year-model and i see over the top of it, just barely. I am 5 ft. 10 in.
For that particular model Givi part no. 323dt here is the description.
The GIVI 323DT is a taller clear windscreen for the Honda PCX 125 and PCX 150 scooters (2010-2013). This replacement windshield is 32.2 inches high and 22.8 inches wide. The 323DT is approximately 16 inches taller than the stock wind shield.
Keeping that in mind, the tall Givi for the newer PCX is 32.1" H x 21.7" W
- Testerpt5
I am considering getting a spoiler for the windshield, but I am afraid the givi windshield might break due to the extra weight from the spoiler, for those who dont have the Givi tall windshield at speeds higher than 60mph (100kmh) the top of the windshield bends quite a bit, in the beggining I thought it was going to break.
- Testerpt5
Forgot to add the while going at 60mph the noise inside the helmet is considerable, and decided to test and see what would happen if I put my hand sideway on top of the windshield, the sound was greatly reduced, thus the interest in the extra spoiler.
