It is currently Sat Feb 17, 2018 6:42 pm
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: 12V SOCKET
PostPosted: Tue Jul 25, 2017 6:28 am
Offline
Hi all, a bit embarrassed about this question but here goes.
Can i hard wire a 12v socket to the battery? i have done this on every motorbike i've ever had but i have no idea how the stop start system on the pcx works and wasnt sure if there is a conflict. it will be an always on socket with no LEDs, hasnt drained batteries in the past.
This is just for my heated jacket as it needs a 7amp fuse and the stock pcx socket is only 1 amp
cheers
Top
 Profile
 Post subject: Re: 12V SOCKET
PostPosted: Tue Jul 25, 2017 7:21 am
Offline
Color: blk
Of course you can. Just connect your neg and positive to the respective battery terminals. Be sure to install a fuse (holder) on the red + side. All is Ok no interference.
Top
 Profile
PostPosted: Tue Jul 25, 2017 8:55 am
Offline
Fantastic. Cheers!
Top
 Profile
PostPosted: Tue Jul 25, 2017 9:40 am
Offline
Year: 2013,2014
Color: red+redder
You can buy all these parts from Battery Tender. That's the way I get power for my jacket : The basic Battery Tender permanent hookup to the battery and the removable Battery Tender "cigarette lighter" attachment connected to the permanent hookup. Works great -- the fuse is already in the permanent hookup and the only time you draw power is when you have your jacket plugged in. Plus you now have your battery tender lead right there for charging your battery if you need to. On my PCX I drilled a little hole in the black plastic just above my fuel door for the battery tender lead to exit the battery area.
Johnny
_________________
Top
 Profile
PostPosted: Tue Jul 25, 2017 9:54 am
Offline
I set mine up by running the Battery Tender wires through the seat hinge. That way I didn't have to drill any holes in the plastics. The adapter comes with a protective cap, so it is safe when not using it.
https://www.amazon.com/Battery-Tender-0 ... nder+cable
Or
https://www.amazon.com/MOTOPOWER-MP6899 ... 4W8DWTNKEF
_________________
Two Red 2013 Honda PCX150s
Lots and lots of extra lights
Custom seats from Thailand
Bad boy Airhorn on each
Top
 Profile
PostPosted: Tue Jul 25, 2017 3:21 pm
Offline
Just a thought - will the PCX alternator be able to keep up?
Top
 Profile
PostPosted: Tue Jul 25, 2017 3:28 pm
Offline
Location: Lying in the gutter in the centre of the universe
Should do, it's attached to the bike.
_________________
Flu based abstinence
Top
 Profile
PostPosted: Wed Jul 26, 2017 9:33 am
Offline
Year: 2013,2014
Color: red+redder
You you is right (again) !
But seriously, folks, mine has worked for three winters with no problems and I still have the original battery.
Johnny
_________________
Top
 Profile
PostPosted: Tue Aug 01, 2017 11:14 am
Offline
Year: 2013 PCX150
That's not necessarily true. If the heated jacket draws more current than the alternator can supply, you'll be draining the battery just to run the vest.
Also, are you guys using those full-size automotive jacks? They're kind of big for a scooter. I'd be tempted to just rewire the accessory to use a Battery Tender plug. The alternators are rated 343 W. 343 รท 12 V = 28 A max, or 25 A @ 13.8 V. Subtract the load for the headlights (50 W --> 3.6 A or so) and leave enough to keep the battery charged. Figure you have maybe 10-15 A to play with.
_________________
-Jeremy
Top
 Profile
PostPosted: Tue Aug 01, 2017 11:27 am
Offline
"Figure you have maybe 10-15 A to play with."
Except when they don't want to play. Ever seen a runaway amp? They have no intention of ever playing. Funny things, those amps. They can be good until someone opens the gate. Then they go to ground, and then you have a heck of a time finding them. :-/
_________________
Top
 Profile
PostPosted: Tue Aug 01, 2017 12:48 pm
Offline
Biting tongue. :roll:
_________________
Top
 Profile
Who is online
Search for:
Jump to:
