Automatic Seat Lift
Pcxdemon
Automatic Seat Lift
Post by Pcxdemon »
I was bored and i had this hydraulic strut that i bought on webike looong time ago but never ended up using it, that was sitting on the work bench and just staring at me...so last night i thought to finally have a go at installing it...
https://youtu.be/qTuKdGzf3WA
chicaboo
Re: Automatic Seat Lift
Post by chicaboo »
You can do this now:
Pcxdemon wrote:I was bored and i had this hydraulic strut that i bought on webike looong time ago but never ended up using it, that was sitting on the work bench and just staring at me...so last night i thought to finally have a go at installing it...
I like it. A how-to would be great.
I can see how the strut is attached to the seat, but are they self-tapping screws or bolted on the other side? If they are self-tapping, what did you do to prevent the screw end from poking through the seat cushion? If it is bolted on the other side, how did you lift and refasten the upholstery? As well, what length is that strut?
Thanks in advance for any insight you can offer.
Pcxdemon
Post by Pcxdemon »
Screws are small, not self tapping...they are not long and they were supplied with the strut. So no modification needed to any parts of the seat. Literally took 1min to install!
I got the strut from webike, I tried to find the link for it so I can put it on here but couldn't find it again from the brief look. I'll look again later to see if I can find and share it..
d.a.rous
Year: 2014 JF57(125)
Color: Carbonium Grey
Post by d.a.rous »
YSS G-Euro XL Red shock
Dr Pulley SR2015 13g sliders
Dr.Pulley SP2015-AK sliding pieces
SH Clutch (Facilitated)
Malossi Clutch Spring (Red)
High beam Passing (Flash)
Low beam switch (on/off)
Oxford HG "Touring"
Drive Belt Cover + Swingarm (Matt Black)
Michelin City Grip
I have seen a post of the spring depicted in the second link, but can't find it. Someone else recently asked about something like that. That spring looks like it would be less obtrusive than the strut.
chicaboo
Post by chicaboo »
https://japan.webike.net/products/22773433.html
Pcxdemon
Post by Pcxdemon »
The spring is obviously more ideal but the strut is actually not that intrusive unless a full face helmet is required to go under the seat. And it looks the biz... :lol:
Not for $42.44 USD though. :o
lennoxlewis
Color: Grey
Post by lennoxlewis »
its great but now there's no chance of storing a full helmet with chin protection. other that that: LEGEND
Pcxdemon
Post by Pcxdemon »
lennoxlewis wrote:its great but now there's no chance of storing a full helmet with chin protection. other that that: LEGEND
That's correct, however for those trips that require full face helmet there is a good news..this strut literally takes 1 minute to takedown or install back on.
