It is currently Sun Feb 25, 2018 4:44 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: SH125 Over heating Issue
PostPosted: Thu Nov 23, 2017 10:56 am
Offline
Hello All,
I have a SH125 that the cylinder was changed on, and it overheats. It is not burning the coolant, but its not circulating it either. I have checked and do not see a bleed off screw, so the highest point in the cooling circuit is the radiator cap.
Any ideas on how to bleed this system other than taking the cap off and letting the bike idle and "Blipping" the throttle to get the bubbles out. (This is from the Honda Service manual for the PCX)
Many Thanks,
Mark
Top
 Profile
PostPosted: Mon Jan 29, 2018 6:51 pm
Offline
I recently changed the coolant on my scoot, a Honda PCX. I ran the engine, with the radiator cap off, until the thermostat opened and one could the the water flow. You will see bubbles come out and the level go down. Add more coolant as needed until it can't take any more. On my subaru I place a funnel, that fits tightly into the filler neck, so that I don't get as much coolant to overflow. At this point is when you do the blip of the throttle. Finally I turn off the engine and top up the coolant, as it will settle a bit. Also make sure to top up your reservoir tank, as the engine will suck up some coolant when it cools, if it needs it.
Gil
_________________
    2013 Honda PCX 150, NCY Variator kit, Dr Pulley 12g Roller weights
    IRC tires, LED driving lights, Besten trunk
Top
 Profile
Who is online
Search for:
Jump to:
