Page 3 of 3
Re: How-To: Install a Trunk
Posted: Wed Jul 09, 2014 10:35 am
by kramnala58
jcomp5150 wrote:I just wanted to say thanks for all the info and part numbers/vendors. Here are some pics of a successful install after finding all the great advice! Thanks.
It looks good. And by the way, welcome to the forums.
Posted: Tue Sep 23, 2014 5:18 pm
by kcpcx
Thank you for the rack DIY. Very helpful.
I took a slightly different route for the holes, in case it helps anyone.
I didn't have a 7/8" drill bit. Some calculating showed that 3/4" is also very close to 20mm.
I used a Dremel tool with a small sanding drum to fine tune the holes a tiny bit larger after the 3/4" bit. Instead of the round file used in the tutorial. Either way works, just depends what you have on hand.
In particular, the part about removing the little white clips was helpful. Much easier to test fit repeatedly that way before final install.
Posted: Fri May 29, 2015 2:19 pm
by jon_l
Thanks for the great write-up PCX Commuter.
I installed mine today:
Posted: Sat Dec 19, 2015 10:28 pm
by ahsteven
Hi, great tutorial!
I bought a 2011 PCX and someone has already drilled out the wholes in the back. The front two close to the seat are the same as the ones in the images. However the ones in the back are the smaller wholes next to the big ones. Does anybody know of a trunk model that will fit in these wholes?
Posted: Sun Dec 20, 2015 12:38 am
ahsteven wrote:Hi, great tutorial!
Do you have any pictures of the holes?
Posted: Fri Jan 01, 2016 6:51 pm
by ahsteven
- 000_0006.JPG (118.91 KiB) Viewed 1950 times
you you wrote:ahsteven wrote:Hi, great tutorial!
Here you go!
