Page 2 of 3
Re: How To: Install a Trunk
Posted: Wed Jun 12, 2013 11:07 am
by maddiedog
Looking good! I like that new rack, it's nice.
Posted: Tue Jun 18, 2013 2:37 am
by PCX Commuter
I bought the Honda Rear Trunk Base 08L70-KZY-910, and it is indeed very sturdy metal construction. I have not yet installed it because I haven't decided on which trunk to get.
I'm thinking, however, that the Monolock or Monokey universal bases can easily be installed by first drilling mounting holes through the metal Honda Rear Trunk Base.
It might involve holes in a location like this: (I drew in the possible hole locations as a mock-up.)
[/quote]
Great idea! That plate is pretty heavy, but once you drill through, it would never let go! Let us know if you decide to go that way.
Posted: Tue Jun 18, 2013 11:01 am
by sasha82
Very nice write up. One of the best I've ever read with all the pictures I feel it would be a snap.
Can you post a photo with your macbook pro inside the trunk? I just want to see the clearance because I'm still having trouble imaging how it would fit . It's a darn big laptop..
Posted: Tue Jun 18, 2013 11:42 am
by kramnala58
sasha82 wrote:Very nice write up. One of the best I've ever read with all the pictures I feel it would be a snap.
If you are concerned that the 370 won't be big enough, I put a 470 on mine. It might look oversized for the bike in pics, but it real life it doesn't look too big at all. The model I have has the brake (aim) light as well which is a nice feature. You can see it in the "Gallery" section on the "Before and After" thread.
Posted: Wed Jun 19, 2013 2:32 pm
by PCX Commuter
Sure! Here you go.
Posted: Wed Aug 14, 2013 12:52 am
by pphan26
Hi Pcx Commuter,
Just new to these forums and found your install guide really interesting and useful. Just bought a pcx 125 and planning on a top box install using the honda rear plate alongside the givi e370 which you have successfully carried out.
Just need some guidance with step 11 where you did some nice fancy work. Can you explain that part in more detail and also wondering how the top box and rear plate is holding up since the install.
Any guidance would be awesome.
Cheers
Posted: Wed Sep 25, 2013 8:59 pm
by hawkeyegirl
This is a very thorough tutorial! I just received my Givi box and I'm waiting on my Honda OEM bracket. I saw steps 11-11b and I'm wondering if that will be pretty intuitive when I do the install, or are there any other details you could provide on how to rig the Givi mount to the Honda bracket? Thanks in advance!
Posted: Mon Mar 17, 2014 5:41 pm
by 6ftMach1Girl
Thank you for the great pics! I am spending way too much time on this forum!
Posted: Tue Mar 18, 2014 11:07 am
by chucktuna
Great write up.
About the only suggestion I could add is to use these type of drill bits instead of a spade bit:
Posted: Tue Mar 18, 2014 3:36 pm
chucktuna wrote:Great write up.
Xmas trees!,,
Posted: Thu Mar 20, 2014 2:29 pm
by BrAtKo
Hello all any idea where to buy 08L70-KZY-910 trunk in the Europe please ? Postage from US is quite expensive. This part is not officially available on local dealers it seems it is only US part. Thanks.
Posted: Thu Mar 20, 2014 2:54 pm
by iceman
The parts on the list are probably not the style your after, but just in case
http://www.hgbyamaha.co.uk/hgbdaytonash ... CX125.html
Posted: Thu Apr 24, 2014 10:59 am
by BrAtKo
Hello all I've received Honda trunk finally today from US. I'm wondering how to mount the Givi base plate because point 11b of PCX commander photos is not so clear. I'm thinking about drilling the holes anyone already did it ? If so would you mind please to share photos ? Thanks.
Posted: Fri Apr 25, 2014 9:40 am
by maddiedog
BrAtKo, the mounting hardware that comes with the kit typically mounts to the baseplate without drilling. Do the holes not line up?
Posted: Fri Apr 25, 2014 11:46 am
by BrAtKo
Pcx commander has used some different parts not included in honda kit and even in Givi kit.
Posted: Fri Apr 25, 2014 1:04 pm
by maddiedog
The only hardware I don't recognize is on the bottom -- those brackets aren't the same. Typically, a washer and nut is included on the bottom, and they hold the case mounting plate to the rack.
Mel46 has a stock rack with stock hardware, hopefully he or someone else that had the rack can chime in or post pictures of whether or not they had to drill.
Posted: Fri Apr 25, 2014 1:16 pm
by BrAtKo
maddiedog wrote:The only hardware I don't recognize is on the bottom
Exactly same on me.
Re: How-To: Install a Trunk
Posted: Thu May 01, 2014 11:45 am
by BrAtKo
I've already modified it by drilling four holes.
- ImageUploadedByTapatalk1398962736.913703.jpg (149.91 KiB) Viewed 5050 times
- ImageUploadedByTapatalk1398962748.871716.jpg (139.76 KiB) Viewed 5050 times
Posted: Mon May 05, 2014 3:25 pm
by BrAtKo
Posted: Wed Jul 09, 2014 8:58 am
by jcomp5150
I just wanted to say thanks for all the info and part numbers/vendors. Here are some pics of a successful install after finding all the great advice!
Thanks.
- image.jpeg (131.08 KiB) Viewed 2693 times
- image.jpeg (115.57 KiB) Viewed 2693 times
