Will not idle properly or at all
Atrophimus
Post by Atrophimus »
My 2017 Honda pcx 150 will not idle at stops because the kick stand is not in the rite position somehow in the up position. It began by intermittently when I put stand up it wood work fine and idle proper or sometimes stop idling somewhere in the ride and I could just put stand down at next stop and flip it up and back to proper. Now it won't hit that sweet spot and idle at all. The engine lite blinks when it won't idle but stops when idle works. It could b wiggled a bit at first to make it rite bjht not any more. Bypass will not work cause it still won't idle that way. Any ideas to get my idle back?
easyrider
Color: blk
Re: Will not idle properly or at all
Post by easyrider »
Replace switch
