It is currently Sun Feb 25, 2018 8:28 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Tachometer
PostPosted: Mon May 16, 2016 3:45 pm
Offline
Year: 2012
Color: Silver
Hi anyone here has any experience with wiring up tachometer on pcx? Not sure where to get engine signal from. There are two connectors on ignition coil but which one is it?
Top
 Profile
 Post subject: Re: Tachometer
PostPosted: Mon May 16, 2016 4:34 pm
Offline
Location: Lying in the gutter in the centre of the universe
Depends on the tachometer. If you can tell us which one you have it would certainly help.
_________________
Flu based abstinence
Top
 Profile
PostPosted: Tue May 17, 2016 12:38 pm
Offline
Year: 2012
Color: Silver
Cheap one of eBay. Black and red lead for light. Black and green for ground and positive after ignition and yellow for engine signal
Top
 Profile
PostPosted: Tue May 17, 2016 1:15 pm
Offline
If its a 50 dollar Koso tach you will need to ground the black and simply wrap the red around the spark plug wire several times (do not connect red, just coil tightly) Removing the lower panel will take most of your time because I don't think you can get in there without taking the left lower panel off a 2012 model. When taking off the panel place a rag over the kickstand prior to protect your paint. After all screws are out you'll start popping the panel by carefully pulling from the rear by the passenger peg first.
http://www.amazon.com/Koso-BA003040-Min ... tachometer
The Koso works great but the instructions are a little vague. Remember to program it for a single cylinder as it defaults to multi piston bikes... around 1750 rpm when idling will be the proper reading for PCX.
_________________
PCX Whisperers: maddiedog- dem0nk1d- waspmike- dasshreddar- GN- sendler2112- honkerman- DAB- BPT7594- Oyabun- silverantec- chicaboo- ThailandPCX- Dragon_uk- TrumpMAGA- k2apache6.0- pcx power-full- JaeMelo- markgj- Techno
Top
 Profile
PostPosted: Tue May 17, 2016 3:56 pm
Offline
Perhaps ask the sellers? Really cheap rev counters can pick up the signal from wrapping the wire around the HT lead.
_________________
Top
 Profile
PostPosted: Wed May 18, 2016 8:25 am
Offline
Year: 2013 150esp
Color: white/carbon
its the one on the rear side of the bike
Top
 Profile
PostPosted: Thu May 19, 2016 12:35 pm
Offline
Year: 2012
Color: Silver
Tried connecting to the other one first. Probably blown it as it doesn't work on either of connectors.
Top
 Profile
PostPosted: Sun May 22, 2016 12:12 pm
Offline
Color: White.
It's usually the negative side of the coil for the trigger.
_________________
Top
 Profile
PostPosted: Thu Jun 09, 2016 5:59 pm
Offline
^^ That's exactly what I'd do. It should pick up the charge on the spark plug wire inductively closely enough to allow you to monitor your RPM.
_________________
Current status: Getting sassed by a toddler that needs a nap, but is too tired to take one
Currently ride: 2011 Honda PCX 125
Previously rides: 2005 V-Strom DL650, 1974 Vespa Ciao, 2011 Honda PCX 170 (Takegawa 170cc big bore kit), 1996 Honda Nighthawk 250, 1987 Honda Spree, 2000 KTM 125SX, 2003 Honda Silverwing, 2007 Genuine Buddy 125, 1998 Honda PC800, 2008 Buddy 125 (white), 2008 Buddy 125 (red), 2001 Honda Reflex, 1987 Honda Elite, 1988 Honda Spree, 2007 Yamaha Vino, 2007 Honda Metro, 2x 125cc pure-chinesium dirt bikes
Top
 Profile
Who is online
Search for:
Jump to:
