Glove Box Lock
Posted: Mon Aug 03, 2015 4:16 pm
by Seph
So as a few of you know I recently had a little spill.
With help from some awesome people on here I was able to order the correct parts to fix my PCX 125 (2015).
whilst waiting for the parts to be imported I've decided to fix the glove box's major problem, the lack of a lock.
Re: Glove Box Lock
Posted: Mon Aug 03, 2015 4:53 pm
by Simon0867
Very neat job, might just add that to my list of future projects.
Re: Glove Box Lock
Posted: Mon Aug 03, 2015 4:56 pm
by Jge64
Very nicely done.....
Re: Glove Box Lock
Posted: Mon Aug 03, 2015 5:08 pm
by Seph
Thank you.
As it doesn't look out of place I've no idea why Honda never fitted one.
When I start replacing my panels I might find a cam lock that isn't too proud, as this one sticks out a little more than I would like. It doesn't cause a problem, more of a cosmetic thing.
Re: Glove Box Lock
Posted: Mon Aug 03, 2015 7:18 pm
by ScooteringAbout
I may steal that idea!
Re: Glove Box Lock
Posted: Mon Aug 03, 2015 8:54 pm
Bravo! You are the first known member to do this. Cheers Seph 8) This thread deserves to be in the "How To" of our PCX Technical sub-forum ;)
Re: Glove Box Lock
Posted: Tue Aug 04, 2015 12:23 am
by Seph
WhiteNoise wrote:Bravo! You are the first known member to do this. Cheers Seph 8) This thread deserves to be in the "How To" of our PCX Technical sub-forum ;)
Awesome news. I did look through the forum to see if anyone had posted any tips but thought I was just not looking deep enough.
Glad you like the mod. If I can help anyone with their own mod please contact me.
Re: Glove Box Lock
Posted: Tue Aug 04, 2015 9:13 am
by maddiedog
Cool how-to! I'm moving this to the how-to subforum. :D
Re: How-To: Glove Box Lock
Posted: Fri Oct 16, 2015 12:47 am
by cathy.fung
Any way this could be done with the 2013 model??
Posted: Fri Oct 16, 2015 4:45 am
by Oyabun
Cathy - unfortunately not. The earlier model has a different mechanism( a latch) to hold the door closed and so the inner side of the door is completely different. I've tried and measured - but could not found a solution so far.
Posted: Sat Oct 17, 2015 10:18 am
by Seph
Hey, you could do this sort of lock on any model but not the same way. The 2015 model has an internal "lip" at the lock arm caught behind. as long as the lock arm can get behind a part of the body it'll work. you maybe could cut a channel in lieu of the internal lip.
Posted: Sat Oct 17, 2015 10:35 am
by Jge64
Seph wrote:Hey, you could do this sort of lock on any model but not the same way. The 2015 model has an internal "lip" at the lock arm caught behind. as long as the lock arm can get behind a part of the body it'll work. you maybe could cut a channel in lieu of the internal lip.
Easily solved with a dremel and a mini drum sander tool.....
Posted: Sun Oct 25, 2015 3:00 pm
by fantasy2c
Just wanted to say thanks for this thread! Because of you posting this i did the same thing today. When the dealer put my bike back together from being hit while it was at work, i couldn't use the glove compartment and when i got it open I busted the plastic tab off so it wouldn't close so this was a double win by adding security and it'll close. Thanks again!
Posted: Mon Oct 26, 2015 6:49 am
by Seph
You're more than welcome Fantasy2c. Glad it's helped.
Posted: Thu Jun 09, 2016 6:10 pm
by maddiedog
Oh wow, I like this one. Thanks, this is a great mod!
I was genuinely concerned about people stealing my insurance cards out of the glove box, it's a common problem around here.
Posted: Thu Oct 26, 2017 9:23 am
by drc
Looks good but think it will not work on a 2013 though. Could you list where you found the lock.
