How-To: Glove Box Lock
Seph
Glove Box Lock
Post by Seph »
So as a few of you know I recently had a little spill.
With help from some awesome people on here I was able to order the correct parts to fix my PCX 125 (2015).
whilst waiting for the parts to be imported I've decided to fix the glove box's major problem, the lack of a lock.
The after.
The after.
And done.
And done.
Had to fashion, bend and shape the Cam lock arm to fit. also included a small strip of weather proof foam to hold the lock tighter.
Cam lock held in place.
backing plate with some sink holes below the clips.
A cover for the hole.
Using a 20mm bit.
Using a 20mm bit.
After measuring the Cam lock I drilled a small Pilot hole.
DSC_1211 (1).JPG (422.99 KiB) Viewed 7642 times
The before. The Duct tape is my temporary fix to my fairing.
Seph
Simon0867
Re: Glove Box Lock
Post by Simon0867 »
Very neat job, might just add that to my list of future projects.
Year: 18 300 xmax
Re: Glove Box Lock
Very nicely done.....
Seph
Re: Glove Box Lock
Post by Seph »
Thank you.
As it doesn't look out of place I've no idea why Honda never fitted one.
When I start replacing my panels I might find a cam lock that isn't too proud, as this one sticks out a little more than I would like. It doesn't cause a problem, more of a cosmetic thing.
Seph
ScooteringAbout
Re: Glove Box Lock
Post by ScooteringAbout »
I may steal that idea!
aka DrewJW
Re: Glove Box Lock
Bravo! You are the first known member to do this. Cheers Seph 8) This thread deserves to be in the "How To" of our PCX Technical sub-forum ;)
Seph
Re: Glove Box Lock
Post by Seph »
WhiteNoise wrote:Bravo! You are the first known member to do this. Cheers Seph 8) This thread deserves to be in the "How To" of our PCX Technical sub-forum ;)
Awesome news. I did look through the forum to see if anyone had posted any tips but thought I was just not looking deep enough.
Glad you like the mod. If I can help anyone with their own mod please contact me.
Seph
Re: Glove Box Lock
Cool how-to! I'm moving this to the how-to subforum. :D
cathy.fung
Re: How-To: Glove Box Lock
Post by cathy.fung »
Any way this could be done with the 2013 model??
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
Cathy - unfortunately not. The earlier model has a different mechanism( a latch) to hold the door closed and so the inner side of the door is completely different. I've tried and measured - but could not found a solution so far.
Seph
Post by Seph »
Hey, you could do this sort of lock on any model but not the same way. The 2015 model has an internal "lip" at the lock arm caught behind. as long as the lock arm can get behind a part of the body it'll work. you maybe could cut a channel in lieu of the internal lip.
Seph
Year: 18 300 xmax
Seph wrote:Hey, you could do this sort of lock on any model but not the same way. The 2015 model has an internal "lip" at the lock arm caught behind. as long as the lock arm can get behind a part of the body it'll work. you maybe could cut a channel in lieu of the internal lip.
Easily solved with a dremel and a mini drum sander tool.....
fantasy2c
Post by fantasy2c »
Just wanted to say thanks for this thread! Because of you posting this i did the same thing today. When the dealer put my bike back together from being hit while it was at work, i couldn't use the glove compartment and when i got it open I busted the plastic tab off so it wouldn't close so this was a double win by adding security and it'll close. Thanks again!
2015 pcx with NYC variator and faceplate and 13g NYC rollers
Seph
Post by Seph »
You're more than welcome Fantasy2c. Glad it's helped.
Seph
Oh wow, I like this one. Thanks, this is a great mod!
I was genuinely concerned about people stealing my insurance cards out of the glove box, it's a common problem around here.
drc
Color: red
Post by drc »
Looks good but think it will not work on a 2013 though. Could you list where you found the lock.
