Page 2 of 2
Re: How-To: Lower both front and back of your PCX 4FREE!!!
Posted: Mon Feb 02, 2015 5:04 pm
dem0nk1d wrote:Side note
What got changed?
Nothing just modified stock springs
Can you back to stock?
Yes if you have stock parts in your inventory
Performance springs?
Possibly a vendor sells performance springs that you can swap out
Seriously don't argue with the Scottish about anything. There is no common frame of reference, just keep on with real life...
Posted: Tue Feb 03, 2015 3:26 am
by iceman
The height of speed-humps in the UK varies, some are nice to go over and some are horrible even at slow speed. Lowing the height of a vehicle in the UK may not be a good idea. Do they have speed-humps in the US? < not ridden there and do not often go there so not sure :)
Posted: Tue Feb 03, 2015 8:34 am
by Urbanfreestyle
Just have to wheelie everywhere..
Posted: Tue Feb 03, 2015 4:06 pm
Urbanfreestyle wrote:Just have to wheelie everywhere..
You can generally ride round the ones down here. Bonus, no slowing down
Posted: Tue Feb 10, 2015 12:24 pm
by magic_mike
on my zuma I slid the fronts up higher into the triple tree
keeping the same travel, but made it lower
I had to cut out some of the plastics above as the shocks would hit and rub
but thats stuff you dont see
is that possible for the pcx
Posted: Tue Feb 10, 2015 12:47 pm
by Urbanfreestyle
I don't know for sure but i don't think so as the forks are scored so they lock into place
Posted: Tue Feb 10, 2015 4:26 pm
by dem0nk1d
Mike,
it's possible but i would not advise it, as they have this notch or indentation for the top bolt.
Posted: Tue Feb 10, 2015 4:52 pm
by homie
what if you want to jack it up higher?
Posted: Wed Feb 11, 2015 8:55 pm
by dem0nk1d
homie wrote:what if you want to jack it up higher?
PVC spacer in the shock tube, would rise the bike if you wanted that 4x4 mode!
Posted: Sun Feb 15, 2015 11:27 pm
by maddiedog
I like the cost of this mod (FREE!!!). I wouldn't do it on my PCX though, the suspension already bottoms out for me over some bumps. I can't imagine how easy it would be to bottom out with less spring. My city has a lot of potholes and I do a lot of curb hopping, so I can imagine this mod would work well for someone in a city with well-maintained roads.
Did you notice reduced cornering clearance? I removed my centerstand for more cornering clearance and to prevent the infamous crankcase break that only happens on the 2011 model, but I still rub my plastics from time to time. This would bring you closer to the ground, meaning less potential lean angle.
Posted: Mon Feb 16, 2015 8:11 pm
by dem0nk1d
I have my center stand removed. I still have no issues with in turns. But in no way am i dragging knee, and scrapping panels.
