How-To: Solve a Soggy Hump On The Cheap (not fully serious)
EddieC
Post by EddieC »
So, as you can probably tell today is a day off and im bored and maybe a little sarcastic. :lol: Been reading a lot about people having a wet ass from the hump after rain. Thought I would share a simple and free solution.
Tools/Supplies needed:
-Plastic bag
-scissors (optional)
Step 1:
Cut or tear out bottom of bag
Step 2:
Open PCX seat and place bag around seat and hump
Step 3:
Close seat
And BAM! All done! Good job! Now your hump wont be soggy after the rain! Doesnt look good but it sure is simple to use. And cheaper than a cover :D
Woolley
Re: How to solve a soggy hump on the cheap
Post by Woolley »
wow, you gotta get on dragons den!
ImageImage ImageImage Image
EddieC
Post by EddieC »
HAHA! maybe I should! We have a similar show here in the US called "Shark Tank"
Sadly, I'm not allowed on that show because one of the investors is my aunt, Barbara Corcoran =]
Woolley
Post by Woolley »
You must have a rich family. Wish my aunt was some sort of business moneymaking genius :lol:
EddieC
Post by EddieC »
nope. just a rich aunt =] :lol: But its still pretty cool! I guess if I ever really had a good idea I could just pitch it to her in person...
Woolley
Post by Woolley »
heres some:
a see through toaster so you can see when your toast is just right.
central locking for your house.
pringle cans that twist up from the bottom like lipstick.
Woolley wrote:central locking for your house.
You would just end up locked out....
Woolley
Post by Woolley »
:lol:
cheap shot!
:lol: :lol:
This is by far the most useful how-to here. I should sticky it. :P
EddieC
Post by EddieC »
You know me Dave... :lol: Always trying to help =]
Scottish
Post by Scottish »
Off-cut of neoprene cut to size...(take no notice of the white strips or superglue which i didnt use)
the idea was to create a watertight seal but the hard plastic ridges prevented the neoprene from being flush with the hump, however after tightning the hump as much as possible it worked out pretty well... next is to get a blow torch and melt those pesky ridges down.
I take it thats the top of the hump. Wouln't the threaded sections stick in yer bum?
Scottish
Post by Scottish »
qed wrote:I take it thats the top of the hump. Wouln't the threaded sections stick in yer bum?
Scottish
Post by Scottish »
no glueing needed just tighten bolts with a ratchet.
You know what a ratchet is?
Just a bit bigger than a mouse sh1t :lol:
Scottish
Post by Scottish »
:lol:
So all silliness aside, did this actually work? Because I went to dinner with a soggy ass last week because my hump was still retaining water 3 days after rain...
Scottish
Post by Scottish »
Indeed it did Dave, after a torrential downpour I tried it out and came back with a dry posterior :D
I will be happier when i remove the ridges so its totally flush at the 'bottom' but that aside it works,
3mm neoprene off cuts for £3 ~ http://www.ewetsuits.com/cgi-bin/sh0000 ... 3a579#a579
Scottish
Re: How-To: solve a soggy hump on the cheap
Post by Scottish »
well i need to update this !!
over time the neoprene acted like a sponge...anyway I've now used some sugru and so far it seems to be working.
Scottish
Water proof seat hump
Post by Scottish »
After trying a few different methods I can finally say the only thing that really worked was sugru self setting rubber, even after a heavy downpour or leaving the bike out all night in the rain, the next day you can be confident of nothing seeping through and giving you a soggy behind.
Its even heat and cold resistant to 180C / -50C, so no melting in the hot sun or cracking on a winter morning.
Application tips : Dont remove the hump and apply a bead of sugru around the perimeter of it, this is what I did initially but it didnt quite work, what to do is make sure the hump is screwed in as tight as possible then with a finger, smear the sugru into the edge like you would if you were grouting some tiles, this ensures a completely watertight seal.
It really makes a difference knowing youre not going to end up with a wet arse.
http://sugru.com/about
