The Honda PCX / Honda Forza / SH Forums
Your predominant source of information for the Honda PCX 125, Honda PCX ESP, Honda PCX 150, and Forza. Now featuring a SH300i / SH150i subforum!
It is currently Sat Feb 24, 2018 9:07 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sun Jul 06, 2014 12:29 am
Offline
So here we go again one of dem0nk1d's epic DIY with massive photos for detail. Better go grab a cold one!
Tools:
MIG Welder
Angle Grinder
Cut off wheel
Flapping Disc
Blue tape
Safety Glasses
Decided I'll make the cut at the end cap behind the weld, and start from that weld line to 7"
Sharpied in the 7" mark
All taped up for guides
And so it begins!
I had to section out the rear of the exhaust because the inside tubes go into the end baffle
Baffle is spot welded into the out exhaust shielding, and i thought it was going to be easy
Has to finish the rest of the pipe off with a sawzall this basically released the rear section of the exhaust and reviled the CAT
Mayhem!
Cat materiel is pressed into the inner tube, the main header tube i guess you could say. I used a number of drill bits to loosen this stuff up.
Perfectly gutted!
Main plastic shielding mount has to go!
Take your cutoff wheel and get close ass possible then work at the rest of the metal with the flapping disc
Try to get the cap matted up with the other half as perfect as possible this will make welding things back together much easier
I then went back over the welds and grinded them down and tried as best as possible to smooth them into the pipe
Mounted and ready to go!
So the main question is how does it sound? If you imagine or have ever been to a destruction derby, it's like that! I'll try to post a video later, but even the audio can't compare to the real thing. I'll be testing some other designs for the internal baffling situation to make it A LOT more quite! More or less going with that perforated steel. We will see how long it takes for me to get rolled by the cops. I have feeling it will be soon.
Top
 Profile
 Post subject: Re: DIY Shorty Exhaust
PostPosted: Sun Jul 06, 2014 2:14 am
Offline
Year: 2013 PCX 150
What did it do to performance? How did it affect the power band?
Top
 Profile
PostPosted: Sun Jul 06, 2014 7:40 am
Offline
dem0nk1d, I always look forward to your DIY postings. Nice work.
Thanx again.
_________________
Previous - 1986 Honda Elite 250, 2007 Ninja 500r
Current - 2013 Honda PCX-150
Top
 Profile
PostPosted: Sun Jul 06, 2014 12:24 pm
Offline
Seems like when i get on it, at Wide Open Throttle the speedo needle moves very fluid. But the real test is when i go to work today for inventory. I'll be hitting the freeway.
Top
 Profile
PostPosted: Sun Jul 06, 2014 7:16 pm
Offline
Conclusion is that the pipe is too free flowing and doesn’t make enough back pressure at high RPM. Other than looking better, it’s extremely loud. I’ll be creating some kind of baffle during the week to come. However I did have a few people take photos of me on the freeway ride to work. LOL…
Top
 Profile
PostPosted: Sun Jul 06, 2014 10:02 pm
Offline
Location: Niagara Falls, USA (formerly in Bangkok, Thailand)
If you were wearing the crown I can understand whey they were taking the photos. ;) :lol:
_________________
2009 Yamaha Majesty YP400 in USA (Metalic Titanium) - "The Throne"
Top
 Profile
PostPosted: Mon Jul 07, 2014 10:12 am
Offline
Video Clip!
Top
 Profile
PostPosted: Mon Jul 07, 2014 10:24 am
Offline
Year: 2014 (UK)
I really want to hear this thing!
_________________
Honda PCX 125 ESP (Black)
Top
 Profile
PostPosted: Mon Jul 07, 2014 10:45 am
Offline
I'm up to 12 or 13 now...
You crazy man!
_________________
Top
 Profile
PostPosted: Thu Jul 10, 2014 9:50 am
Offline
Okay second round, lets split this BISH open AGAIN! (Facepalm)
Objective is to remove the main exhaust tube as far into the muffler as possible
Okay this was the most difficult part trying to figure how to get inside the pipe to cut the pipe as far back as possible. My solution was using a dremel to get things started, tin snips, and time
Slight bevel on the can and a clean surface to weld to
Now time to create the baffle. With the left over piece of pipe i used paper to give me a pretty accurate messurement of the OD of the pipe. This way we can slide the baffle over the smaller stub in the muffler.
All marked up... Aprox 5.5 inches from memory Using the paper as a template to transfer into the Preforated Steel Sheet
Using the old piece of pipe to help shape the handmade baffle
Review:
Basically I didn't stuff the muffler with fiberglass packing, as the muffler is all welded up. But I did add the perforated steel line, and even add it on the exit hole to reduce the chance of sparks. So in the end result going with prototype 2 what do I think of it? It’s registering at 86 DB at idle, isn’t raspy as it was purely gutted. I’ve gained some back pressure, and it’s tolerable now. Hell this morning on the way to work the CHP passed me and didn’t even look at me. So all in all it passed the test!
Top
 Profile
PostPosted: Thu Jul 10, 2014 4:10 pm
Offline
Awesome mod. Way, WAY cheaper than getting one of the coffee can-looking exhausts and probably just as effective.
What type of welder do you have, and any advice for someone who is interested in learning how to weld?
_________________
Current status: Getting sassed by a toddler that needs a nap, but is too tired to take one
Currently ride: 2011 Honda PCX 125
Previously rides: 2005 V-Strom DL650, 1974 Vespa Ciao, 2011 Honda PCX 170 (Takegawa 170cc big bore kit), 1996 Honda Nighthawk 250, 1987 Honda Spree, 2000 KTM 125SX, 2003 Honda Silverwing, 2007 Genuine Buddy 125, 1998 Honda PC800, 2008 Buddy 125 (white), 2008 Buddy 125 (red), 2001 Honda Reflex, 1987 Honda Elite, 1988 Honda Spree, 2007 Yamaha Vino, 2007 Honda Metro, 2x 125cc pure-chinesium dirt bikes
Top
 Profile
PostPosted: Thu Jul 10, 2014 4:56 pm
Offline
maddiedog,
I’m a full time rookie, part time fabricator. Actually the whole story with me and the wife moving into the house, was that the garage is mine. Then she gave me a 2k limit on what I wanted to buy. This was back in May of this year. To make a long story short. I bought a Miller MVP 211 Dual Voltage mig welder. I figured that ever post I read said go the biggest you can guy.
I got the welder for 850 used (Retail 1200-1300 not including tax) on Craigslist, and came with regulators. I still needed to purchase a bottle, which I got the biggest bottle I could which is the 120-125cfm bottle. Here’s the deal with Argon/Co2 mix gas. It cost a fraction more to fill a 120-125 bottle than an 80 bottle. I do mean a fraction like a whole 10 bucks, for almost double the amount of gas. You want to weld with gas. Also here in California, the bigger bottles are Buyer OWNED. So you can find a used one like I did for 120 bucks. Also the great thing is it was out of date, and would have need Hydro Testing… But had a westair sticker on it. I brought it back to them and they just exchanged it for the price of a fill 88 bucks. A new bottle that size is around 240 bucks, not including gas
So anyhow I’m going on a tangent… Depending on what you want weld, it depends on the machine. I think you can get away with most light duty work with a 130amp 110/120v box. You’ll need to use a 20amp breaker and line. I wired mine directly to a single 120v 20amp outlet. Then next to that is my 240v outlet. 240v machine would blow holes through sheet metal.
Other than that I’m just learning. This was actually my first real mig welding project. Anymore question I can answer when I get home.
Peace! Leaving work!!!! PCX is waiting for me as we speak…
Go with a name brand Mig welder too, I've made the mistake in the past and tried the HF box... Man did that suck..
Top
 Profile
PostPosted: Fri Jul 11, 2014 4:41 am
Offline
Year: 2014 (UK)
If you need anyone to 'test' out the mound jot me down!
_________________
Top
 Profile
PostPosted: Fri Jul 11, 2014 8:49 am
Offline
maddiedog,
oh and go with gas, flux core welding is for welding outside in the elements. think farm life!
Top
 Profile
PostPosted: Sat Jul 12, 2014 11:00 am
Offline
Year: forzaruckuspcx
Hey maddiedog,
If it helps, I just use a Lincoln wire feed welder(home depot $400) non gas, 110v...
works for all my household and scooter needs :)
Top
 Profile
PostPosted: Wed Aug 27, 2014 4:07 pm
Offline
Good job!! I wish I could weld like that... (I have a stick welder ;) )
_________________
2015 Honda PCX 125
Top
 Profile
PostPosted: Wed Aug 27, 2014 9:37 pm
Offline
htp 221dv tig welder ;) ... I did the same thing to my ruckus muffler but left some of the baffling in it.
Top
 Profile
PostPosted: Wed Sep 24, 2014 1:31 pm
Offline
Ever give any thought to stretching out some steel wool and stuffing it around the mesh section? I've had to use steel wool in automotive mufflers before and it worked well. Not sure how such a small engine would respond to it though.
Great write-up and pics.
Top
 Profile
PostPosted: Sun Apr 16, 2017 8:43 am
Offline
I'm bumping this for the exhaust hole drilling lovers out there. :P
Top
 Profile
PostPosted: Sun Apr 16, 2017 10:58 am
Offline
Color: blk
I love doing projects like that. Too often however the results are usually negligible and more costly than buying ready made. Great job, but wondering about the final result. Were you trying to gain HP , noise, weight difference.. What ?? and did you succeed in your final outcome?
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
