How-To: Delete Your Fender Like a Pro
Posted: Thu Jun 19, 2014 9:29 pm
by dem0nk1d
That's right no more paying over priced delete kits for your fender. Here's my how-to came up with it in my head on the way home from work.
Tools Need
Vibrating oscillating saw (harbor freight version is killer with half moon metal wood blade)
File for smoothing out the plastic
Ummmm Beer????
Stock factory whale tail
Now lets get started
use the factory line that was created from the mold when they made the fender
Here you can faintly see the factory line
The plastic slag left behind from the saw, no get your file out
Purdy
Done!!! This is the version 1 creation... Just wait it gets more intense!
Now for version 2 not for the noobie! So pay attention and take your time!
First removing the factory plate mount
Now it's time to remove the section of the fendor where the lisense plate light goes. Pull on the wires behind this peice as the light is held in with a rubber socket
Again use the factory mold line to get everything dialed in perfectly
Finally removed the lower section
TAKE YOUR TIME NOW IF YOU FFFFFFFFFFF UP IT IS ON YOU!!! <---DISCLAIMER!!!
NOW SLOWLY Take little pieces out enabling you to open up this area of the fender. You can use the lines where the curves meet each other.
Getting closer to flushing this section out
TADA!!! We have a winner!!! No paying 100+ bucks for a fender delete kit
Hope you guys enjoy this!
Re: How-To delete your fender like a pro
Posted: Thu Jun 19, 2014 11:39 pm
by Mgalutia88
Ha ha, I did v1 three weeks ago. Nice and easy and looks WAY better.
Posted: Fri Jun 20, 2014 6:03 am
by Slickvic
Nice job!
Thanx for sharing.
Posted: Fri Jun 20, 2014 8:24 am
by kramnala58
Strictly my opinion, but I like v1 better than v2.
Posted: Fri Jun 20, 2014 11:05 am
by dasshreddar
o_O EXTREME! :lol:
So where is your license plate light going to go? Those cops will get you. :?
How about trimming a bit more like this...
Posted: Fri Jun 20, 2014 11:58 am
by dem0nk1d
dasshreddar wrote:o_O EXTREME! :lol:
The license plate running light wiring is already behind the fender. I’m going to add the little led plate lights. They serve as a bolt and lights to be complaint for the law. So far when I’ve been riding it’s been in day light so it gives me some time this weekend to fix the lighting situation for the Cali cops. =S
I also will need to get the small round red reflectors for the bottom of the plate to be legit as well. I didn’t have enough time yesterday to find them from the move or they would have at least been installed. I all most thought of reusing the side reflectors as a joke. =)
Was joking with my buddies last night about the reflectors… HEhehe Cops would have a field day!
Posted: Fri Jun 20, 2014 12:07 pm
by Mgalutia88
Isn't there already a place for the plate light in the clear space under the tail lamp? Could that work?
Posted: Fri Jun 20, 2014 12:23 pm
by dem0nk1d
Mgalutia88 wrote:Isn't there already a place for the plate light in the clear space under the tail lamp? Could that work?
Version 1 would be fine now need to add lights since it is there. My version 2 mod gets rid of that light box area. But slims everything a lot. More to come.. when i get home...
Posted: Fri Jun 20, 2014 1:19 pm
by Mgalutia88
I'm talking about the clear portion of the tail lamp housing under the brake lamp.
Posted: Fri Jun 20, 2014 1:35 pm
by dem0nk1d
Sorry sometimes I’m trying to post so fast the words in my head get mixed up. What I wanted to say is Version 1 is simple. Just cut once and your done. You get to keep the factory light, no more mods needed.
Now version 2 you’ll need to add some LED lights so everything is legit at night. I know what you said, it’s just me being retarded on trying to get my words out correctly through the keyboard…
this is what i will install above
Posted: Sat Jun 21, 2014 6:27 pm
by maddiedog
I got a good laugh at "whale tail" -- I removed the stock mudflap and put on an Ermax undertray right after buying mine.
How did you mount the plate on that hole?
Posted: Sun Jun 22, 2014 12:22 am
Tempted by the mkI version
Posted: Mon Jun 23, 2014 10:51 pm
by dem0nk1d
maddiedog wrote:I got a good laugh at "whale tail" -- I removed the stock mudflap and put on an Ermax undertray right after buying mine.
There is enough surface area for the plate to be screwed into. I will take pictures of the plate off the bike.
Posted: Mon Jun 30, 2014 9:52 am
by dem0nk1d
Here are the led bolts, i added last night.
Posted: Mon Jun 30, 2014 10:08 am
by kramnala58
Looks good. It is too bad that the US/Canada models have the signal lights on post. I know they are more visible, but imo they detract from the look of the bike.
Posted: Mon Jun 30, 2014 11:04 pm
by dem0nk1d
kramnala58 wrote:Looks good. It is too bad that the US/Canada models have the signal lights on post. I know they are more visible, but imo they detract from the look of the bike.
Your absolutely right! I might head down to Mexico since it's fairly close to me, about 45 min drive and check with the Honda dealer down there. See how much the fender and turn signals are. Do you happen to know if they make a delete fender kit that is compatible with the JDM turn signals? I've seen that they too attach to the stock JDM fender.
