It is currently Sat Feb 24, 2018 4:52 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: PCX SEAT CHANGE - HOW TO
PostPosted: Sat Jan 11, 2014 10:26 am
Offline
Year: 2014 (2015)
I thought I would post this 'How To' to help anyone thinking of changing their seat on their PCX (possibly for a 'non-hump' version like I have.)
Apologies in advance for the average quality 'phone pics.
I bought my new seat from: http://www.powerbypcx.com
This is the one I ordered: http://www.powerbypcx.com/achat-selle-t ... 69418.html
It cost me £121 including delivery/shipping and taxes/duty.
It is very well made/stitched in a sort of 'carbon look' material
They use genuine Honda seat bases and retrim . . .
You can see the holes where the 'hump' bolts normally go . . .
The new seat has the lock 'hoop' attached as well - so no messing about required there . . .
Top
 Profile
PostPosted: Sat Jan 11, 2014 10:35 am
Offline
Year: 2014 (2015)
The job itself is really easy . . .
After unlocking the seat, tip it fully forward and locate the two nuts holding it to the hinge . . .
(Circled in red)
With a 10mm socket, remove the nuts . . .
And then remove the seat by slipping the studs from the holes in the hinge.
Once off, turn the original seat over and carefully remove the rubber seal . . .
Then, install the seal in the new/replacement seat, with the join at the front (hinge end) of the seat . . . there is a channel in the seat base that holds the seal very snug - it's very easy to replace/fit.
Then slide the two studs on the new seat into/through the hinge, slip the nuts on and tighten using the socket.
That's it! Your done! No more Quasimodo!
(Hope this helps.)
Top
 Profile
PostPosted: Sat Jan 11, 2014 10:50 am
Offline
Thanks Mr. Rascal. That is a nice looking seat. It is good to see that the original seat gasket is not glued onto the seat and comes off easily and that Power By PCX uses authentic Honda seat bases. That should reduce any fitment problems.
Did you lose any under seat storage with the new seat? My helmet barely fits in there now.
_________________
Top
 Profile
PostPosted: Sat Jan 11, 2014 11:26 am
Offline
Year: 2014 (2015)
No dude, it's exactly the same.
Same base, same space. :)
Top
 Profile
PostPosted: Sun Jan 12, 2014 10:01 am
Offline
Year: 2013 PCX 150
Some of the aftermarket seats use a different base with a lower seat height. I also found that this seat requires adjusting the seat latch by pushing it up against the bolts that hold it on to latch easier. I know there is not much there however there is enough to make a difference in how they close. You can do this easily with a ratcheting 10mm box end wrench. Loosen the bolts until the latch moves around and then pull up on the latch while tightening down the bolts.
Top
 Profile
PostPosted: Sun Jan 12, 2014 10:36 am
Offline
Year: 2014 (2015)
This (my) seat ^ required no adjustment at all - totally 'like for like' (same base.) :)
Top
 Profile
PostPosted: Mon Jan 13, 2014 7:25 am
Offline
my only reservations with aftermarket seats is that there can be a huge diference in the quality.....
A lot of seat companies use a cheap seat base which is flimsey and doesn't shut properly...and to add insult to injury, can leak....
i've also seen ones that leak through the stiching, meaning the foam quickly becomes wet and the seat starts to smell......
if at all possible, imho - get your originall honda one recovered/restyled and be careful who does the work...
As they say down the local fish market..."Caviar Temptor".....
Top
 Profile
PostPosted: Wed Jan 22, 2014 5:17 am
Offline
Year: 2014 (2015)
The one above ^ uses a genuine Honda base.
And the 'trimming'/'re-covering' is superb in my opinion.
I did 20 miles on it yesterday (the weather here has been crap - and I only ride for pleasure, not 'commuting') - it's way better than the factory seat - for me at least. :)
Top
 Profile
PostPosted: Mon Feb 03, 2014 10:57 am
Offline
Moved this to the proper subforum. Thanks for the helpful how-to. :D
If your aftermarket seat did not come with trim, see here: viewtopic.php?f=3&t=2108
_________________
Current status: Getting sassed by a toddler that needs a nap, but is too tired to take one
Currently ride: 2011 Honda PCX 125
Previously rides: 2005 V-Strom DL650, 1974 Vespa Ciao, 2011 Honda PCX 170 (Takegawa 170cc big bore kit), 1996 Honda Nighthawk 250, 1987 Honda Spree, 2000 KTM 125SX, 2003 Honda Silverwing, 2007 Genuine Buddy 125, 1998 Honda PC800, 2008 Buddy 125 (white), 2008 Buddy 125 (red), 2001 Honda Reflex, 1987 Honda Elite, 1988 Honda Spree, 2007 Yamaha Vino, 2007 Honda Metro, 2x 125cc pure-chinesium dirt bikes
Top
 Profile
Who is online
Search for:
Jump to:
