The Honda PCX / Honda Forza Forums
http://hondapcx.org/
Forza 125 replacement battery
http://hondapcx.org/viewtopic.php?f=29&t=7968
Author:  rollmops [ Fri Aug 11, 2017 4:05 pm ]
Post subject:  Forza 125 replacement battery
Hi
I need a new Battery for my Forza.The O.E.M is rather expencive with 77£.
Can anyone recommend a cheaper option,Iam in UK.
Thank you.
Author:  V8vor [ Sat Aug 12, 2017 1:33 am ]
Post subject:  Re: Forza 125 replacement battery
Hi Rollmops
Has your battery died? Mine died as a result of the harness issue, however my local Honda dealer fitted a new battery foc before I had the replacement harness replaced, however they did recommend a battery charger/ maintainer which I duly purchased ( Oxford maximiser 3000 I think) bit expensive at £70 but well worth it, every time I put the bike in the garage it goes on charge.
If you've not had the replacement harness I'd book it in as its free of charge but might take a couple of days to fit.
Regards
Drew
Author:  you you [ Sat Aug 12, 2017 2:24 am ]
rollmops wrote:
Hi
Thank you.
eBay?
Author:  rollmops [ Sat Aug 12, 2017 9:18 am ]
you you wrote:
rollmops wrote:
Hi
Thank you.
eBay?
Nope..its even more expensive.
Cheapest i found
Code:
http://www.wemoto.com/bikes/honda/nss_125_forza/15/picture/battery_oem/
Author:  rollmops [ Sat Aug 12, 2017 9:40 am ]
V8vor wrote:
Hi Rollmops
Regards
Drew
My Battery is still OK, sort of.It does take a few more turns to start, but then after over2 years no surprise. It will be getting colder soon and my bike is parked in the street.Charging the battery all the time is not really an option.
I get a new Battery and keep the old one charged as a backup.
My harness has been replaced,so no issues there.
Author:  gn2 [ Sat Aug 12, 2017 9:29 pm ]
According to this its a Yuasa YTZ8V
According to this chart the YTX7L-BS battery is a very close match and should do the job.
Battery2u list the YTX7L-BS as the one for the job and it can be had for much cheapness elsewhere.
The one aspect the cheaper YTX7L-BS battery doesn't match is the CCA (cold crank amps) rating, however that's only likely to be a problem in extreme cold when you probably won't be using the scooter anyway.
Page 1 of 1 All times are UTC - 5 hours
Powered by phpBB® Forum Software © phpBB Group
http://www.phpbb.com/
