Front Suspension
Mark2260
Color: Blue
Front Suspension
Post by Mark2260 »
Hi,
So i have found the YSS front suspension kit for the new Forza 300 Y-FCC28-KIT-01-018, everywhere i looked just showed the 13-17 models kit, the question is will it be worth the £200 asking price?, I nearly part xed it because of the soft front end that bottoms out too easily with my svelte 106kg arse on it, but it does everything I need for commuting on.
The back end seems ok for now on the number 4 setting, i know some have tried with the aftermarket valve but has anyone tried the full kit? it should have springs,valves, preload adjusters and spacers it says, will it be a stiffer spring than OEM?.
Thanks for any info
Mark
YBR125 07, CG125 07, CBR300R 15, CB500F 66, current: Forza 300 19
