The Honda PCX / Honda Forza Forums
Your predominant source of information for the Honda PCX 125, Honda PCX ESP, Honda PCX 150, and Forza 300. Now featuring a Forza 125 subforum!
It is currently Sat Oct 21, 2017 7:47 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Tue Jan 24, 2017 11:37 am
Offline
Year: Forza 300
Color: red/2014
lucalazio wrote:
Just a last question: where can i connect the ground of grips?
Is there a ground connect near the fuse box?
Thanks in advance and bye, Luca.
Luca,
Yes, the Green/Black wire (part of the red-capped diagnostic plug) IS a ground wire. Just
remove that red cap and connect your grips' ground wire right there. I can't remember of
any 'metal' in the area.
Top
 Profile
PostPosted: Tue Jan 24, 2017 1:39 pm
Offline
Color: Forza 300 Grey
Thanks.
Is this the red-capped diagnostic plug?
If it is, where it is in the wiring diagram?
What's its name?
Thanks and bye, Luca.
Top
 Profile
PostPosted: Tue Jan 24, 2017 1:57 pm
Offline
Year: Forza 300
Color: red/2014
Honda calls it DLC (Data Link Connector). On the diagram, it is located right next to Fusebox 'A'.
Yes, the one with the red cap. You can discard that cap no problem and use its G/Bk as ground.
Top
 Profile
PostPosted: Tue Jan 24, 2017 2:22 pm
Offline
Year: Forza 300
Color: red/2014
Luca,
I wish to add : make sure that G/R wire is big enough to carry the grips current, though.
IMO it should be able to handle the grips' 4 amps (but I have no exact idea on its AGW rating, so
can't take any responsability, here. 'Check if it gets hot' is my best advice.
Top
 Profile
PostPosted: Wed Jan 25, 2017 2:57 am
Offline
aguim wrote:
...and use its G/Bk as ground.
aguim wrote:
...make sure that G/R wire is big enough to carry the grips current...
Sorry, the ground will be the G/Bk of DLC but the 12V will be the R/Bu of ACC. Is it right?
What's the G/R wire?
Top
 Profile
PostPosted: Wed Jan 25, 2017 7:45 am
Offline
Year: Forza 300
Color: red/2014
Luca,
ERROR. Should be GREEN/BLACK. I was in a hurry, thinking of 'GRound'
Top
 Profile
PostPosted: Wed Jan 25, 2017 8:09 am
Offline
:D :D :D
Thanks, carissimo.
Do you think that the use of DLC ground doesn't create problem to the electronic on board?
That's a simple ground or not?
Bye, Luca.
Top
 Profile
PostPosted: Wed Jan 25, 2017 10:23 am
Offline
Year: Forza 300
Color: red/2014
Luca,
All the Green and Green/Black wires end up bolted together to the frame, behind the right side
plastic side cover. I think they thus can all be seen as 'simple' grounds.
The G/Bk ones indeed serve as sensors' grounds. I can't see how using one as 'ordinary'
ground could disturb the electronics, since they all end up grouped together, anyway...
Personally, I would use the INPUT R/G as feed, and remove the windshield + top cover to find
a more solid ground. Not that I don't think other setups wouldn't work, but only to make sure I'm
200% covered.
Top
 Profile
PostPosted: Thu Feb 16, 2017 1:39 pm
Offline
Yeah!!!
Finally installed!!!
The cables:
The red arrow shows the used fuse for positive.
The negative is connected directly at the battery.
The controller:
Fantastic!!!
Thanks for all your helps.
Bye, Luca.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
