Hello, I bought my forza in october but unlike the PCX where its extremely easy to find & buy a trunk mount for, I for the life of me cannot locate one for the Forza.
Does the Forza have a buyable mount anywhere? I've attached a picture of the trunk that I have. Worked perfectly with the PCX, eager to put it on my Forza considering the bad underseat storage.
Trunk Mount?
- Color: Red Forza
Trunk Mount?
- temp.jpg (49.22 KiB) Viewed 2423 times
Re: Trunk Mount?
Try Givi. I have a Givi 65 liter case on my 2014 Honda Forza 300.
Or you can make one pretty easily with 4 bolts, spacers & flat plate. Bolt holes are there under the rear plastic, even marked on the back of the plastic. You need to drill the plastic.
Re: Trunk Mount?
Or you can just leave the plastic trim piece off.davenowherejones wrote:You need to drill the plastic.
That way you can remove the rack without having to buy a new trim piece.
- Color: Forza red
Re: Trunk Mount?
I went to Revzilla's site, told them what bike I had, what topcase I wanted to mount and they gave me the info I needed. I ordered the mount from them and it fit beautifully (about $96 but well worth it). My topcase is a Givi monolock and the mount went right into the marked spots on the tail.
