Page 1 of 2
Malossi rear shocks (twins!)
Posted: Thu Jun 09, 2016 3:36 pm
by MBMyer
Well, last Sunday I swapped out the stock rear shocks for a set of Malossi shocks. It took very few minutes (despite going ahead and removing the lower rear body piece (two screws, three tabs).
With the stock shocks, I was preloading at the 4th tab but still bottoming out over speed bumps. With the Malossi shocks, I am currently riding at the second stop on the shocks and may drop down to the lowest detente. The ride feels much better, I have yet to bottom out over any of the nasty speed bumps that are part of my life, and do not hear the squeak that was so, so common with the stock shocks.
Also, the preload adjuster is up at the top of the shocks and very easy to turn with a gloved hand. The stock shocks have the adjuster down low, and I found it very awkward to adjust them, even with a pin wrench.
Now I just have to find some suitable fix for the front forks, which feel horrible on the last 1/5 mile of the road into work, which is spalling in a very nasty fashion.
Re: Malossi rear shocks (twins!)
Posted: Thu Jun 09, 2016 8:38 pm
by davenowherejones
I have a 2014 Forza with 24,000 kilometres on it. I weigh about 200 pounds fully geared up.
I am trying to decide where to adjust the stock shocks.
Yes it is kind of awkward to get at that adjuster. Mine was full of mud and hard to turn. I put a big wrench in the spring and relieved the pressure by prying the wrench to sit on top of the tire. Easier to turn with no pressure on the adjuster.
But where should it be set?
Posted: Tue Jun 14, 2016 7:45 am
by davenowherejones
I tried the stock shock at full hard and then full soft. The Forza seems to handle the same either way but the soft was easier on the spine.
Do the Malossi make the Forza corner any better? Or is it just a comfort thing to use them?
Posted: Tue Jun 14, 2016 2:45 pm
MBMyer wrote:Well, last Sunday I swapped out the stock rear shocks for a set of Malossi shocks. It took very few minutes (despite going ahead and removing the lower rear body piece (two screws, three tabs).
Trying a heavier fork oil is always worth a first punt
Posted: Wed Jun 15, 2016 7:52 pm
by MBMyer
davenowherejones wrote:Do the Malossi make the Forza corner any better? Or is it just a comfort thing to use them?
I have no firm data, but seat-of-the-pants impression (ha!) is that these are a great improvement. Riding one-up on the stock shocks, I was most comfortable at the middle preload setting. Most of the year, I was commuting with myself (200 lbs) and a skinny teenager (125 lbs) my one school bag, his backpack and computer briefcase. Under those conditions, I had to have the stock shocks at least at the next-to-stiffest preload, and was happiest at stiffest. Even so, going over the speed bumps in the parking lot (and often over the spalled asphalt leading to our school's gate) the rear shocks squeaked a lot and often bottomed out.
On the Malossis, I am running one-up at the lowest preload. When I put the wife on the pillion (somewhere between the skinny teen's 125 and my portly 200), I put the preload in the middle position (3 of 5). They have never bottomed out, but don't feel horribly stiff. The back end feels better and smoother. I feel more confident.
Sorry it's just anecdotal but not hard data. It's the best I can do.
Posted: Wed Jun 15, 2016 7:57 pm
by MBMyer
you you wrote:Trying a heavier fork oil is always worth a first punt
Even if it feels like the front end is rattling in an excessively hard fashion? I feel like what I want is a softer ride overall with a stiffer preload and better rebound damping.
Posted: Wed Jun 15, 2016 10:22 pm
by davenowherejones
MBMyer wrote:you you wrote:Trying a heavier fork oil is always worth a first punt
I had the dealer look at my front forks 15,000 km ago. They put in a plastic spacer and increased the oil weight. It does not seem to bottom out as bad as it used to.
I recently changed the rear from full hard to full soft. It seems to handle the little bumps smoother now. The big bumps before used to scare me. The bike was never out of control but my PERCEPTION was that it was dangerous so I slowed down dramatically.
Our roads are far from perfect, the cold in Canada does nasty things to asphalt.
Posted: Sat Feb 18, 2017 8:49 pm
by Ole
For Christmas this year, I bought myself a pair of Malossi shocks for my Forza. $250 on eBay. I waited til I had about 300 miles on them before giving my spin on these.
I would buy them again in a heartbeat. There really is no difference on monster rim bending Wisconsin potholes but where they really shine is those abrupt expansion cracks. With the stock shocks those cracks were murder on my backbone. Now I just glide right over them my back does not complain.
Not the kind of guy to spread bullcrap. If I thought these Malossi shocks were crap I would be the first to say so. And eat my $250 as a bad buying decision. I can't say that. These shocks work for me. Middle preload setting and I go 210#.
Posted: Fri Mar 17, 2017 5:15 am
by fish
Ole wrote:For Christmas this year, I bought myself a pair of Malossi shocks for my Forza. $250 on eBay. I waited til I had about 300 miles on them before giving my spin on these.
Specifics on the shocks please...and a photo?
Thanks for honest sounding appraisal!
Posted: Fri Mar 17, 2017 9:10 pm
by Ole
$249 Scooterpartsco.com
I've been tinkering around on the pre load. But I always seem to go back to middle position.
They adjust on top and one doesn't need a tool. Just strong hands.
Did not use torque wrench to install. Just a tiny drop of Locktite and sunk em down tight.
Maybe 10 minutes top to get the job done.
Posted: Fri Jun 02, 2017 6:12 pm
by MBMyer
OK, I posted a query in another thread, but wanted to give a heads-up here.
After only about a year of service, my Malossi shocks are weeping oil. I’ll try to post a couple of pictures in a little bit. To my mind, this is unacceptable.
I do not want to put my stock shocks back on, and am hoping to hear about longevity of YSS shocks for the Forza 300.
Michael
Posted: Fri Jun 02, 2017 6:24 pm
MBMyer wrote:OK, I posted a query in another thread, but wanted to give a heads-up here.
Michael
What warranty do you have on them?
Are they re-buildable?
Posted: Fri Jun 02, 2017 8:02 pm
by MBMyer
you you wrote:What warranty do you have on them?
I have no idea what warranty I have on them, nor whether they are rebuildable. I want to bolt parts like these on and then forget about them. I ride this bike nearly every single day and don’t have time to be dealing with failure.
The ride has been significantly better, so much so that I'm willing to keep washing the oil off until a different set of shocks get here rather than put the stock shocks back on. But if I hear that the YSS work well over quite a few years and miles, I’ll order a set of those and dump the Malossis.
Posted: Fri Jun 02, 2017 8:10 pm
by MBMyer
Here are pix of top and bottom on one side. The other side looks about the same.
- IMG_2457.JPG (441.76 KiB) Viewed 4281 times
- IMG_2456.JPG (431.94 KiB) Viewed 4281 times
Posted: Sat Jun 03, 2017 9:15 am
by waybar
I had the malossi shocks put on my scooter before the beginning of riding season last year, so far no weeping oil. Keeping fingers crossed. Happy with them so far.
Posted: Sat Jun 03, 2017 9:43 am
by MBMyer
Oh, and it only just now occurred to my fatigued and aging mind that what might be more helpful than months of service is miles of service.
These weeping shocks have ~3500 miles (~5600 km) on them.
Posted: Sat Jun 03, 2017 6:09 pm
MBMyer wrote:you you wrote:What warranty do you have on them?
In that case, next time, it might be better to check? Aftermarket parts are rarely as reliable as OEM.
Posted: Sat Jun 03, 2017 8:53 pm
by MBMyer
you you wrote:In that case, next time, it might be better to check? Aftermarket parts are rarely as reliable as OEM.
I have found that, often, aftermarket is better and more reliable than OEM. I lost track of the number of microswitches that were changed out under warranty on the Wing, and both sets of hand controls were replaced for broken internal switches. After the bike went out of warranty, when something died, I changed it my own self and used aftermarket. Not a single one of the electrical components I replaced with aftermarket died. And the aftermarket suspension components were far superior to OEM. In fact, the OEM rear came without having air bled out. Taking care of that was a delightful afternoon.
As far as checking before I buy, that’s kind of what discussion boards like this one are for. I read everything I could about the Malossis and the YSS, saw equally good comments about both, and went with the cleaner look of the Malossi shocks. Performance has been much, much better than stock, but both shocks are weeping oil, which I had not seen any comments about. And so I’m commenting about my experience with them after relatively few months and miles.
Pax et bonum,
Michael
Posted: Sun Jun 04, 2017 2:32 am
MBMyer wrote:you you wrote:In that case, next time, it might be better to check? Aftermarket parts are rarely as reliable as OEM.
Pax et bonum,
Michael
Is there any way you could find out if you have a warranty on the shocks? Perhaps contact the seller or view their website?
Posted: Sun Jun 04, 2017 4:03 pm
by waybar
MBMyer wrote:Oh, and it only just now occurred to my fatigued and aging mind that what might be more helpful than months of service is miles of service.
For the record, I have 2526 miles on mine so far, so have a little ways to go to catch up to you yet. Will see how they are doing in another 1000 miles.
