Cruise control
Cruise control
Just letting you guys know that the vista cruise control is a must have for your forza. Cheap, easy install and functions well. I love mine about 33 bucks on ebay.
- image.jpeg (80.82 KiB) Viewed 3150 times
Re: Cruise control
too scared to use one
Re: Cruise control
It just mechanically locks the accelerator hand control to a certain position, right? How does that work in conjunction with emergcency braking or just having to slow down suddenly for road conditions i.e. off accelerator and start braking. Looks like you have to release it then worry about braking - not sure how that would work where you have a very short time to respond.
- Year: 18 300 xmax
Re: Cruise control
All these locks just create enuf tension to hold it open, it is easily overridden by rolling the throttle,back. Of course you can be an idiot and install with too much tension but....
I’ve used them for years, no prob....that being said, my pcx is for around town, this mod is not heeded on my pcx, but would use on my CTX.....
Re: Cruise control
its not meant for in town obviously, i use mine when i travel from vegas to san diego. The throttle assist is okay but you cant let go to relax your wrist.
- Slowinitdown
Re: Cruise control
On an old cb500 I used to do loads of motorway riding and when I wanted to I just put a rubber o ring between the throttle and bar stop. It held the throttle in whatever position you wanted so you could ease your wrists. £1.50 part that you can install or uninstall whenever you liked.
Re: Cruise control
Hell even a condom might work if you can find the right size.Slowinitdown wrote:On an old cb500 I used to do loads of motorway riding and when I wanted to I just put a rubber o ring between the throttle and bar stop. It held the throttle in whatever position you wanted so you could ease your wrists. £1.50 part that you can install or uninstall whenever you liked.
Installation instruction not included!
Re: Cruise control
Vegas to SD ... sounds like a neat ride !! Do you ever take a route thru the Mojave? I drove a car from the Grand Canyon to SD - used Rt66 as much as possible, loved it, had a blast around that old airbase near Kingman and then further south in Oatman, wished I was doing it on a bike.its not meant for in town obviously, i use mine when i travel from vegas to san diego. The throttle assist is okay but you cant let go to relax your wrist.
I think I had a similar control on an older MC that I once had ..... I could adjust the tension so that it would hold a set, but any wrist movement could override that. And it had a similar "on - off" flipper switch that I see on yours. Can't you tighten the tension any more so you can maybe relax your wrist?
Re: Cruise control
This looks a whole lot easier than the mods I went through to get the Vista Cruise throttle lock to work:
http://hondapcx.org/viewtopic.php?f=23&t=4987
6 other previous bikes
Re: Cruise control
an other options ( very cheaps ena easy )
https://www.youtube.com/watch?v=oX-thYSTUGk
https://www.youtube.com/watch?v=2nRPwMeN4fY
https://www.youtube.com/watch?v=_F8ySR72y6o
