It is currently Thu Jan 18, 2018 4:58 pm
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: Forza Coolant Change
PostPosted: Wed Dec 27, 2017 7:15 pm
Offline
Year: 2016 Forza
This summer I am going to change the Forza Anti-Freeze.
There is a drain plug on the water pump cover to drain the system and the overflow tank can be siphoned empty.
So, you remove the radiator cap and fill the system and the overflow tank.
So, should you keep the radiator cap off, run the engine, will the new Anti-Freeze be drawn into the system, then fill the system again and close the radiator cap.
Some cars do fine with just filling the radiator with anti-freeze and closing the cap, while other cars will draw down the anti-freeze when run, then fill the radiator again and close the cap.
Top
 Profile
 Post subject: Re: Forza Coolant Change
PostPosted: Wed Dec 27, 2017 8:53 pm
Offline
If you like, I can photo the 3 pages of photos and instructions from the official Honda service manual and post them here tomorrow. This way you can do it as instructed by folks who built your red scooter.
No problem....too cold to ride in Ohio.
Top
 Profile
PostPosted: Thu Dec 28, 2017 1:50 pm
Offline
Color: blk
Just drain both radiator and coolant recovery tank.Refill both tanks using an antifreeze suitable for aluminum metals.Most name brands will be fine for this.Start engine and burp the system by loosening bolt .There is port in the plastic panel.Once burped check all tanks for proper levels.I believe 50/50 mix is adequate solution.
Top
 Profile
PostPosted: Thu Dec 28, 2017 2:30 pm
Offline
Year: 2018
Maybe all 'Name Brand' coolants are silicate-free and otherwise compatible nowdays, I'm not sure. But I do know that many Honda coolant pump seal failures have been the result of scoring/deterioration caused by incorrect automotive coolant. But maybe the new automotive mixes have resolved that.
Top
 Profile
PostPosted: Thu Dec 28, 2017 3:02 pm
Offline
Color: Silver
Where is the burp bolt?
Top
 Profile
PostPosted: Thu Dec 28, 2017 4:30 pm
Offline
Color: blk
Under luggage lid.. Look for small maintenance access cover .Start engine run it for a few (hot) then open bolt to burp any air. You may need to use a new sealing washer but I never did. Refill with any silicate phospate free anti freeze with any good brand like Prestone , Zerex,Peak compatible with aluminum engines doesnt have to be Honda but if you are psychologically motivated by HONDA hype then use HONDA brand ???.
Top
 Profile
PostPosted: Thu Dec 28, 2017 6:15 pm
Offline
Location: Lying in the gutter in the centre of the universe
Top quality :lol: :lol:
_________________
Flu based abstinence
Top
 Profile
PostPosted: Fri Jan 12, 2018 4:54 pm
Offline
Year: 2016 Forza
Thanks for the input, guess I'll us the GM Dextron pink anti-freeze, mix with distilled water...
Top
 Profile
PostPosted: Sat Jan 13, 2018 7:17 am
Offline
And a slice of lemon..hic
_________________
Top
 Profile
PostPosted: Sun Jan 14, 2018 4:00 am
Offline
According to the Honda service manual, you should also remove the left lower skirt and disconnect the two hoses behind it to fully drain the system.
Top
 Profile
PostPosted: Sun Jan 14, 2018 8:12 am
Offline
Color: blk
X2 Thats what I do..and very easy to do. GM anti freeze is equal or better than HONDA brand .Prestone "all makes and models" is best imho, but any good quality brand will do.
Top
 Profile
Who is online
Search for:
Jump to:
