Best way to lift a Froza 300 to change rear shocks
Posted: Sun Jul 16, 2017 6:01 pm
by Southbed
Does anybody know the best way lift and stabilize the Forza 300 to change rear shock?
Re: Best way to lift a Froza 300 to change rear shocks
Posted: Sun Jul 16, 2017 8:29 pm
by davenowherejones
I would hang it from my ceiling in my shed or use a bike lift. You could also change one shock at a time maybe using the centre stand. A piece of 2x4 jammed in the right place could also be used.
Posted: Sun Jul 16, 2017 9:05 pm
by Southbed
Excellent thank you.
Posted: Sun Jul 16, 2017 10:30 pm
by SteveP
Put it up on center stand and do one side at a time. No 2x4 or other lever needed...virtually no spring load to overcome when Forza on center stand as shock is pretty much fully extended.
Posted: Mon Jul 17, 2017 1:05 am
SteveP wrote:Put it up on center stand and do one side at a time. No 2x4 or other lever needed...virtually no spring load to overcome when Forza on center stand as shock is pretty much fully extended.
X2
Posted: Mon Jul 17, 2017 3:10 pm
by Southbed
Thank you for all of the help.
Posted: Mon Jul 17, 2017 6:27 pm
Southbed wrote:Thank you for all of the help.
De nada amigo.
Posted: Wed Jul 19, 2017 8:56 am
by MBMyer
X2
x3
This is exactly the procedure I used.
Posted: Wed Jul 19, 2017 3:05 pm
by GeorgeSK
So - what shocks are you going with, and where are you getting them from?
Posted: Wed Jul 19, 2017 5:41 pm
by Southbed
YSS Shocks Model TC 302-400T
EPM Performance Imports, Inc.
HYPERPRO,GAZI USA, RUN-N-LITES, YSS USA,
77 Pension Road., Suite 17
Manalapan, NJ 07726
732-786-9777
Klaus Huenecke (sales@yssusa.com)
Talked to Klaus, He is presetting the shocks to my weight with gear
Before they ship. So I will have little if any adjustments.
Hope this helps.
Posted: Wed Jul 19, 2017 6:33 pm
by GeorgeSK
Couldn't ask for more! Thanks, Southbed.
Posted: Wed Feb 21, 2018 8:13 am
by CamboForza
I am going to adjust the settings on mine and as you all know the exhaust gets in the way at the back for the spanner to get in there.
If I put it on the center stand and unbolt that shock at the bottom so I can pull it back to adjust the setting, do I need and type of Threadlocker to bolt it back up?
Also, does anyone know offhand what size spanner/wrench I need for the bolt on the shock?
Cheers.
I am looking at the YSS TC-302-400T but I don't want to spend the money yet and https://bikerzbits.com/honda-forza-nss- ... orber.html are charging a lot more on the .com than the .co.th part of their site not including shipping once you do currency conversion.
Posted: Wed Feb 21, 2018 8:23 am
by Jge64
I would be using red loctite #271.....perm lock
Posted: Wed Feb 21, 2018 8:56 am
by CamboForza
Jge64 wrote:I would be using red loctite #271.....perm lock
Cheers, I'll make sure I pick some up.
Hang on the product specs say...
Loctite Threadlocker Red 271 is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
I want to be able to undo it one day...lol.
Posted: Wed Feb 21, 2018 9:52 am
by Southbed
I would use the loctite Blue for the bolts on your shocks. I have great success with the blue and use it for all of the fasteners.
Do not use the torque specs. in the manual, they are set for steel and most after market shocks are aluminum. so no more the 4-7 inch lbs.
with the loctite just a little past tight let it set you should have no issues.
Enjoy the ride.
Posted: Fri Apr 06, 2018 11:34 pm
by CamboForza
Funny, I went through the tool pouch and found that I have the Honda Factory shock adjuster kit included.
I'm going to try the softest setting to see if that makes it a bit more compliant. I am only 76Kg.
I'm not ready to go and buy new shocks this month or next.
Posted: Sat Apr 07, 2018 3:47 pm
by SteveP
Southbed wrote:YSS Shocks Model TC 302-400T
Manalapan, NJ 07726
732-786-9777
Hope this helps.
I see this is from last year. How did the new shocks perform? Is the ride better?
Posted: Sat Apr 07, 2018 9:40 pm
by davenowherejones
I am 90 kg and I have my rear shocks on full soft.
I jam a big screwdriver in the shock spring and gently pry upward to turn the adjuster by hand.
I like it better on full soft, full hard was harsh.
