Forza 300 Front disk warp.
Flybywyre
Post by Flybywyre »
After about 2000 miles my Forza 300 developed a pulsating when the front brake was applied. The dealership told me this was due to a warped front disk and it was replaced under warranty. Now, after about another 2000 miles, it has happened again with the new disk.
The symptoms on both were the same, starting with just a slight pulse which then developed over about 500 miles to a very noticeable pulsating, especially if only the front brake is used. I feel that this could be hazardous on wet roads.
The rear brake is working perfectly.
Before I go back to Honda I thought I would post on here to see if anyone else has experienced similar problems?
davenowherejones
Re: Forza 300 Front disk warp.
Post by davenowherejones »
Others have reported theirs are warped. I have a strange bounce/vibration at 120 kmph. I guess I need to check my front disk.
Is there going to be a 2017 Forza 300? Or is the City Adventure 750 the replacement maxi scooter?
DioTiAma
Year: 2013 NSS300A
Color: Seal Silver
Post by DioTiAma »
beegmouse wrote:
They also (dealership) mentioned that the Forza is being discontinued this year and not being replaced. I have had some good rides on it and It did the job. But overall customer satisfaction is low.
There have been reports of warped front discs but warped rears are more common.
Make sure the dealer overhauls the caliper to make sure its not sticking and make sure the wheel bearings are not worn out.
ScooteringAbout
Post by ScooteringAbout »
I have only seen a handful of Forza 300's on the road.
aka DrewJW
davenowherejones
DrewJW wrote:I have only seen a handful of Forza 300's on the road.
I have never seen a Forza other than mine but I live in the middle of nowhere Hope, BC
beegmouse
Post by beegmouse »
The rear discs warp much less often on combi brake setups. It's a single pot which only gets used in combination with the front brake. It just doesn't generate the same heat the three pots calipers do on the front.
The front is just under rated for the weight of the bike. Three pot calipers are rare on single disc setups, and even more so on such small discs with zero float. Basically, they stop great, but they generate too much heat in an emergency stop, and because they can't float when they expand they bend themselves. So unless you can pull away instantly and keep the discs spinning you bake a small patch and it ruins them.
I have never seen three pot calipers on non floating disks. similar weight scooters have either twin disks (Bergman) or two pot calipers (Silverwing) or floating discs (J300/Kymco/Kawasaki)
Flybywyre
Post by Flybywyre »
What are floating discs?
ScooteringAbout
Probably not good but the last Forza 300 I saw was on the lifts at AllBikes Rochdale, and give it was a 2014 plate, the corrosion was o_O
No wonder they have none in their showroom ( bar the 125 Forza which I know little about )
aka DrewJW
Flybywyre wrote:What are floating discs?
Disks that have little bobbins in so the swept area is free to float. Sound great but I've never seen an advantage in braking. Exactly the opposite tbh
Flybywyre
Post by Flybywyre »
Thanks, I think I've got that :)
beegmouse
Post by beegmouse »
Floating discs don't affect the performance at all.
They allow the disc to expand when it gets hot.
If they are fixed(Not floating) when they get hot/expand they exert huge forces. This is what usually causes warp.
beegmouse wrote:Floating discs don't affect the performance at all.
Huge forces on what?
So I think you are saying, in your roundabout way, without saying it, and yet saying it, is that that floating disks perform better as they don't exert huge forces (on something) and don't warp?
That's not true is it..
beegmouse
Post by beegmouse »
Not quite
The stopping power/performance is unaffected be they floating or not.
Floating disks can just handle thermal expansion better.
beegmouse
Post by beegmouse »
The forces I mention are on the disk.
Similar affect as the attached video.
https://www.youtube.com/watch?v=8g-2QX1Kitg
but much higher temperatures, producing much stronger forces.
