Front wheel removal
Posted: Mon Aug 10, 2015 5:59 pm
by davenowherejones
What size hex driver do I need to remove the front axle of a Honda Forza 300?
It looks like a 16mm.
Re: Front wheel removal
Posted: Mon Aug 10, 2015 9:30 pm
You need two, one for the lock bolt and another for the spindle.
No idea what size they are though.
Posted: Tue Aug 11, 2015 2:06 am
by Oyabun
On the PCX the spindle is 14mm and the lock bolt is 19.
Knowing the reuse engineering of Honda, I would be surprised if it would be different on the Forza.
Posted: Tue Aug 11, 2015 7:46 am
The Forza 300 has a completely different wheel spindle attachment, there's no wheel nut, the spindle is threaded and you need a large male allen key to undo it.
Posted: Tue Aug 11, 2015 8:02 am
by Oyabun
My mistake then. Please disregard my previous post.
Posted: Fri Sep 11, 2015 11:56 am
by davenowherejones
davenowherejones wrote:What size hex driver do I need to remove the front axle of a Honda Forza 300?
A 16 was too loose and my 17 would not fit but the Lordco store 17 did fit. I took a grinder to my 17.2 and made it a 17.
Posted: Fri Sep 11, 2015 1:25 pm
Why when the second 17mm fitted?
Sooooo. As to size I'm suspecting its probably 17mm...
Posted: Mon Oct 30, 2017 11:13 am
by MBMyer
So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
Posted: Mon Oct 30, 2017 11:33 am
by MBMyer
MBMyer wrote:So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
Nevermind. It’s an 8mm hex driver for the pinch bolt. And the 17mm fits perfectly for the axle.
Sorry to trouble y’all for no good reason.
Michael
