oil filter
garrup
oil filter
Post by garrup »
..........has anyone found a cheaper source for the oil filter (Forza 300) than the one Honda sells?
willajabir
Re: oil filter
Post by willajabir »
I goto NAPA, Autozone, or Advanced auto and get the Bosh 3300
Here is a list from another board:
About 2.5 inches long. (stock size)
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
Wal-Mart SuperTech ST6607
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
my Forza pics: http://tinyurl.com/o9hqc4o
Re: oil filter
Honda part number is 15410-MFJ-D01
Genuine Honda one costs less than fifteen dollars.
Can't believe you would bother trying to find one cheaper than that given how long it lasts.
AustinPCX
Re: oil filter
Post by AustinPCX »
gn2 wrote:Honda part number is 15410-MFJ-D01
I bought 2 of the 15410-MFJ-D01 from partzilla.com @ $8.40 ea. plus $5.95 for shipping.
Nice little oil Change how-to here if you need it. http://myforza300.wordpress.com/2014/05 ... il-change/
garrup
Re: oil filter
Post by garrup »
..........Honda sells them for $20 here in Canada, and i was told by the parts guy that that's a steal compared to some of their filters.
But you need to change them at every oil change. That's every 3000km right?
Which is about every month. So there goes $20 for the filter and $15-$20 for the oil (yeah, this is Canada).
That would buy 3 gal gas and get me 240 miles down the road.
Re: oil filter
garrup wrote:But you need to change them at every oil change. That's every 3000km right?
Yes and no.
Yes: you change them at every service
No: after the first service at 1000km the service interval is 12,000km or a year whichever comes first
forza300
Re: oil filter
Post by forza300 »
Just a thought to share after reading this...
I sometimes flush the engine with a little spare oil. It adds another couple of steps to the process but helps get rid of any nasty bits in the engine.
After you remove the old oil and filter, simply clean and re-fit the OLD filter first. Then top up with oil as normal (I even have been known to use car oil or whatever is laying around).
Run the engine for a few mins then drain and remove filter as before.
This is a quick "flush" if you like to call it that using a cheap oil, not any nasty chemicals.
It helps, especially in high-mileage engines that haven't had an oil change in years and look like treacle.
jburner
Year: 2013 PCX
Re: oil filter
Post by jburner »
Resurrecting an old post, but discovered today that FRAM makes a filter that is up to the same specs as the Honda Filter. FRAM XG6607 and is sold by Wal-Mart for $9. If there isn't a dealer nearby or want a bit of a break on pricing, check this one out.
http://www.silverwing600.com/t9544-oil- ... a-cut-open
