It is currently Fri Jan 19, 2018 4:02 pm
Post new topic Reply to topic  [ 20 posts ]
Author Message
PostPosted: Sun Nov 10, 2013 1:35 pm
Offline
The other day, I filled the tank and, of course, I got the needle pegged at full.
Yesterday, I ran a couple of errands and put 44 miles on the bike, but the needle is still pegged at full. I thought maybe there was something wrong, so I stopped the bike and powered down. The needle dropped to zero when the power was shut off, and when I started it up, it resumed it's place above full. I thought there might be something screwy in the pressure of the tank, so I stopped the bike and popped the filler cap -- started up all was as before -- still pegged. Stopped again, and looked inside the tank, and the gas is below where it was when I filled it, 44 miles ago.
Any hot'n'dirty fixes (I don't want to mess with too much before the 1st tuneup which should be in a couple of weeks. I can just assume that I need to fill up every so often and make sure I don't run out of gas, but I would rather have a working gauge.
I also have to figure out how to change the clock, but I'm assuming that's in the book :)
Top
 Profile
PostPosted: Sun Nov 10, 2013 1:46 pm
Offline
Mine does the same thing. It stays on full for quite a while. I thought maybe I filled it up too much, but I put it up the plate (bar thing) inside the fill neck. You could always just not fill it so full... ;)
The clock was pretty simple to set. I looked in the manual and it was just a couple of clicks.
_________________
Rides 2014 Honda Forza, 2012 Honda Ruckus
Top
 Profile
PostPosted: Sun Nov 10, 2013 8:23 pm
Offline
Year: SV650AL7
Color: The correct one
Mine does it too, the easiest thing is to simply ignore the gauge and go by the trip meter and economy meter.
_________________
Top
 Profile
PostPosted: Mon Nov 11, 2013 12:37 am
Offline
Location: Lying in the gutter in the centre of the universe
Tbh just about every vehicle I've ever owned has dome this to a greater or lesser degree
I'm sure it's to make the fuel consumption look more favourable
_________________
Flu based abstinence
Top
 Profile
PostPosted: Mon Nov 11, 2013 11:05 am
Offline
Well, I decided to just watch it. This was only the second tank of gas I had had in that bike.
20 miles into a 100 mile jaunt -- it finally showed below full. By the time I got back, I was down to 1/3 of a tank. I ran a couple of errands. This morning, when I head out, my first trip is to the gas station. :)
Thanks for the feedback.
Top
 Profile
PostPosted: Mon Nov 11, 2013 11:14 am
Offline
Car too. The last 4 bikes I have bought have had no fuel gauge, just 2 trip meters.
David
_________________
Other rides
Yamaha MT-01, Yamaha BT1100, Yamaha WR250R, Ducati 900 GTS, Honda VFR 750FV, KTM Duke 690
Top
 Profile
PostPosted: Mon Nov 11, 2013 1:32 pm
Offline
Perhaps better stats might be available over a few tanks
_________________
Top
 Profile
PostPosted: Mon Nov 11, 2013 3:36 pm
Offline
Hi
This is my only annoying issue with the forza , it will show full for a while, but when it gets to the red it's bloody awful, top of the red has about 3 litres left, use the trips and you'll be able to see what your getting to the tank. I'm guessing it's the shape of the tank that is causing the issue
Rubbish compared to the Pcx
My previous fuel guage post is under the general section
_________________
Top
 Profile
PostPosted: Mon Nov 11, 2013 6:14 pm
Offline
Year: SV650AL7
Its really simple, fill tank to the brim, zero trip A and when it shows double what the economy meter shows in mpg there's half the economy meter left.
e.g. when the trip says 150 miles and the economy meter shows 75 mpg there's 37.5 miles left.
_________________
Top
 Profile
PostPosted: Tue Nov 12, 2013 2:07 am
Offline
What's twice the half of one and a half?
_________________
Top
 Profile
PostPosted: Thu Nov 14, 2013 11:22 am
Offline
Yes.
_________________
Top
 Profile
PostPosted: Thu Nov 14, 2013 6:07 pm
Offline
Year: SV650AL7
Wednesday.
_________________
Top
 Profile
PostPosted: Sun Nov 17, 2013 10:52 am
Offline
The speed of a partially-laden swallow.
Top
 Profile
PostPosted: Sun Nov 17, 2013 12:40 pm
Offline
African or European?
_________________
Top
 Profile
PostPosted: Sun Nov 17, 2013 1:06 pm
Offline
International
_________________
Other rides
Top
 Profile
PostPosted: Sun Nov 17, 2013 2:40 pm
Offline
Toyota or real one?
_________________
Top
 Profile
PostPosted: Wed Apr 02, 2014 8:29 pm
Offline
my Toyota yarus does this to I just go by the odom
Top
 Profile
PostPosted: Thu Apr 03, 2014 4:01 pm
Offline
I reckon it's taken from the car gauges which usually leave a gallon in reserve.
Not much use when you only have 2.5! :D
_________________
Top
 Profile
PostPosted: Thu Apr 03, 2014 8:03 pm
Offline
Forza fuel tank is 3.0 US gallons. I multiply the economy meter by 3 and subtract about 10-15 miles to get my upper limit. 25 fill ups so far. Refilled at 2.9 gallons once, usually about 2.7.
_________________
Top
 Profile
PostPosted: Thu Apr 03, 2014 9:46 pm
Offline
I get similar to you. I've got 2700 miles, had 24 fill ups. One of my regular trips is 183 miles one way which I avg 2X/month. Fill up is 2.7-2.8 gallons. I just 3X the meter because it is already conservative by 3-5mpg on mine.
I have a tendency to go the distance when I know the location of the fuel stations.
_________________
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
my Forza pics: http://tinyurl.com/o9hqc4o
Top
 Profile
Who is online
Search for:
Jump to:
